How to replace rotors with pics
jsrbrown
OK... I've searched and found some useful info but not exactly what I'm looking for. Does anyone have detailed instructions from a Haynes or Chiltons on how to remove the front and rear rotors? Also, are new wheel bearing seals a Honda only part?
Thanks in advance
Jim
Thanks in advance
Jim
The MAN....who else?
JS---I just recently did all 4 rotors and the front pads. I can help you with any info you may need on your brakes--I am local to you as well...so--just ask.
The rotors aren't hard. They come off just like any car.
Remove wheels
Remove calipers(2 bolts)
Remove 2 screws that screw into the rotor hub(impact screwdriver helps this)
If they are hard to pull off hit them with a rubber mallet.
The rears are the same, just make sure your parking brake is not on.
Remove wheels
Up from GA
I am in MD for now while my fam is still in GA. Need a good shop to replace front pads and rotor, and maybe rear pads. I don't know how to do it my self, and don't tools here to do it. Any help would be appreciated.
Remove wheels
Remove wheels
^^^ dude always has all the answers!!
Acura Cert MASTER TECH
That big nut is actually your axle nut. Don't worry, you won't have to deal with that at all.
What Fuzzy said is correct, on how to remove the rotors. If you run into problems with the rotor screws, get a chisel and hammer and use that to loosen them. I've found that a 1/2" wide chisel and a good 5lb hammer always seem to do the trick.
Oh and don't forget to hang the caliper with a bungee cord, coat hanger, etc. DO NOT let it just hang by the brake line!
Have confidence in yourself, it's really not hard at all. Good luck with it
-- Kevin
-- Kevin
01 CLS
i was just about to do a brake job on my CLS as well, but does anyone know if the rear caliper is one of those ones that has turned while pushing the piston back in?
jsrbrown
Originally Posted by Buddy4679
JS--when would you be available to get this done? Do you have tools or a place to do the work?
Give me a call or give me your number to coodinate
thanks,
Jim
mada51589
05-03-2022 08:54 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
