how to remove soldered on stuff?
Old Feb 8, 2003 | 01:22 PM
rEmixnZZa's Avatar
okay the previous owner on my car soldered on this useless piece of crap metal that he tried to attach wires to, but he ended up not even using -.- so i have a peice of petal soldered on in my engine bay
how do i remove this? I tried using my soldering thing to melt it but it seems to be on real tight and it won't melt =(
help! its in the way of my strut bar
Old Feb 8, 2003 | 01:25 PM
Titand19's Avatar
East Coast Boost.!
DREMEL
Old Feb 8, 2003 | 07:01 PM
rEmixnZZa's Avatar
wut is dremel?
sorry not very educated in this kind of stuff
Old Feb 8, 2003 | 07:04 PM
allmotor_2000's Avatar
Soldered or welded? Yeah.. use a dremel (tool manufacturer) and a couple of nice bits.. you'll get it off. If its on the firewall or something... you might need to paint.
http://www.dremel.com/html/home_fr.html
Old Feb 8, 2003 | 07:50 PM
Tom2's Avatar
Unregistered Member
If it's just solder, it will come off from the heat of a soldering gun. Just give it more time to heat up.
But if it's WELDED, a soldering gun won't do jack shit.
Old Feb 8, 2003 | 08:20 PM
EricL's Avatar
Depending on the thickness of the solder and the thickness of the metal, you might need a small propane torch to remove the wires. The other alternative is a GIANT soldering iron.
If you have a small soldering iron and can see that the tip will sink in, you probably are looking at tin/lead or lower temp silver solder. If the tip doesn't melt ANY of the solder, you are probably looking at brazing or welding -- if that is the case, grab a mini-grinder (dremel tool -- as mentioned) and carefully remove the stuff.
If the tip of the soldering iron wont melt a small bit of the solder, your either have (1) a way-to-small soldering iron that is dysfunctional (easily tested by trying to melt a sample of REAL solder) and/or (2) are looking at brazing.
Old Feb 8, 2003 | 11:56 PM
rEmixnZZa's Avatar
it's welded
okay so far i have about half of it off by putting a screw driver where its attached to the surface and just chiselling it away with a hammer
-.- very slow work, will have to finish tomorro mornin
should i get a torch or wut?
Old Feb 10, 2003 | 12:19 AM
EricL's Avatar
Originally posted by rEmixnZZa
it's welded
Keep going, or if your patience runs out, buy a Dremel (they come in handy it's a great tool). As a rule, screwdrivers -- even though they are used as pry bars, scrapers, and chisels -- are not the best implement for the task.
A Dremel with the "right" burr, wheel or grinding stone would do just find.
A shop with an air grinder could probably remove the wire in a minute or two (once they are set up).
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
Acura604
Sep 28, 2015 12:24 PM
lowgrowl
Sep 26, 2015 05:18 PM
