How low can u go?
mister D
Originally posted by 4pumpedCL
My car has about an 8" drop and it doesn't need a camber kit at all. My alignment is flawless
Originally posted by bnavarro
i'm not an expert, but, isn't toe and alignment different things?
toe is vertical (up and down)
alignment is horizontial
toe is (looking down from above)
wheels looking like this: / ------ \
camber is (looking from front or back of car):
caster is some other thing.
i have h&r race springs, lowers f. - 2.2", r. - 1.75". aligned perfectly w/o a camber kit.
Btw, my comptechs lowered my front exactly 1.5" and rear exactly 1.0". I plan to drop at least another inch all around with my coilovers for starters, check the rear camber, and then drop the rear another half inch if I can without too much camber. Our rear cambers and our front toes, it seems, when we drop. The camber can be fixed with a kit, but of course that straightens the wheel out so you might rub which means you can't drop it that low so the camber kit is sorta self-defeating because when you get it you'll just have to raise it back up around to the point where you wouldn't need the kit anymore.
STL TL-S
09-23-2015 08:52 PM
