How to install the Weapon R intake?
Old Dec 24, 2001 | 01:32 PM
CWdub's Avatar
My girl got me a intake for christmas. I have no clue where to begin. What do i need to take out? How long should this take? It is a short ram.
Thanks alot
Old Dec 24, 2001 | 08:09 PM
CWdub's Avatar
How do i do this I need help.
Old Dec 24, 2001 | 10:02 PM
mattg's Avatar
Read the instructions first. Short ram should be real easy, 1hr. max.
Old Dec 25, 2001 | 12:08 AM
CWdub's Avatar
What i dont understand is the hoses. There is two hoses welded together, i think the one is anti-frezze, but the other goes to the intake. It came with one hose for that part. What do i do with the other hose that is the anti-frezze. Remeber there two are welded together.
thanks alot
Old Dec 25, 2001 | 12:33 AM
mattg's Avatar
I had the same question when I installed my cai. You are correct, the other hose is for coolant. You need to go and get 2' of 5/16 fuel line, then instead of running the line around the front of the engine, run it around back and trim to fit. Take off your engine covers and you will see the easiest / cleanest way to run that hose. Spend a little time and think it through, you will be successful. Any other questions, let me know.
Old Dec 25, 2001 | 01:21 AM
CWdub's Avatar
so am i getting rid of the metal bar thats welded completely
Old Dec 25, 2001 | 01:29 AM
mattg's Avatar
Yes.
Old Dec 25, 2001 | 04:59 PM
StypeCL's Avatar
MattG does not know what he is talking about. He has a AEM .
Old Dec 25, 2001 | 05:29 PM
cusdaddy's Avatar
I had the same ?'s when I was trying to insall my Weapon R intake. The instructions are not too great.
Just remove the existing Air Box, remove the connecting hoses and extension. Install the Intake and place both hoses on the intake pipe. (it has space for both). If you go to their website, they have a picture of our car with the Weapon R Intake in it. (I think it is moomaster's). Just make sure ours looks like that.
It is a very easy process. Probably took a little over an hour.
***A word of warning before you install this intake. It makes a constant humming noise when idling. Loud enough to be heard from inside the car. I think the short ram design creates a resonating effect that can get quite annoying. Personally I am used to it and gives my car a unique touch
Just thought I would warn you though. Good luck
Old Dec 26, 2001 | 12:29 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Damn UFO sound...
cycdaniel
Dec 17, 2019 10:58 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
james357
Feb 13, 2016 02:37 PM
nanos
Nov 12, 2015 08:41 PM
Abe_Froman
Sep 16, 2015 01:27 PM
