how hard is it to replace a steering wheel?
Old Mar 22, 2001 | 07:51 PM
Cee eL eS's Avatar
one thats doesnt have an airbag. is it that complicated and can it be done at home, or should i go to a shop?
Old Mar 22, 2001 | 10:20 PM
soopa's Avatar
The Creator
id have to say its prolly pretty simple...
(moving to Car Talk)
2001 Acura 3.2 CL Type-S
San Marino Red (Navigation)
PIAA 19173 Ion Yellow Fog Lights
Aftermarket Black Wood Trim Kit
Old Mar 22, 2001 | 11:46 PM
CLpower's Avatar
teh Senior Instigator
question? why would you want to?
Old Mar 23, 2001 | 02:38 AM
260 HP's Avatar
It's very easy. Just open the center cover to find access to the center nut. I think most Japanese cars use 21 mm nut. You just hold the steering wheel with your thighs while you're loosening the nut with a cross bar or something else. Just loosen the nut enough but don't remove it all the way. Then just hit the wheel with your hands on 12, 3, 6, and 9 o'clock position to loosen the wheel. When it's loose, you can pull it out after you remove the nut. Or, you can also use a puller. I hope this helps.
Old Mar 23, 2001 | 09:49 AM
Cee eL eS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CLpower:
question? why would you want to?</font>
i have a '91 integ and i can get an after market steering wheel for cheap. i figure y not if its not that complicated...
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
