how hard is it to replace a steering wheel?
id have to say its prolly pretty simple...
(moving to Car Talk)
2001 Acura 3.2 CL Type-S
San Marino Red (Navigation)
PIAA 19173 Ion Yellow Fog Lights
Aftermarket Black Wood Trim Kit
It's very easy. Just open the center cover to find access to the center nut. I think most Japanese cars use 21 mm nut. You just hold the steering wheel with your thighs while you're loosening the nut with a cross bar or something else. Just loosen the nut enough but don't remove it all the way. Then just hit the wheel with your hands on 12, 3, 6, and 9 o'clock position to loosen the wheel. When it's loose, you can pull it out after you remove the nut. Or, you can also use a puller. I hope this helps.
<font face="Verdana, Arial" size="2">Originally posted by CLpower:
question? why would you want to?</font>
