How about this Tranny Cooler?
Old Mar 18, 2003 | 01:43 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Is it any good?
http://www.v6accord.com/forums/showt...threadid=19479
Old Mar 18, 2003 | 03:45 AM
tw1112's Avatar
If you do buy from him, I can say that he is a really nice guy and responds to questions really fast. I've been asking him about some things and he always responds really quickly with thorough answers.
Old Mar 18, 2003 | 07:56 AM
Rescuer's Avatar
Evil Bob Knieval
the B&M supercooler is $55-65 bucks at most places. i have one installed but really haven't noticed anything new as far as "helping" my tranny. but how knows, it probably is
Old Mar 18, 2003 | 11:20 AM
Caddy©'s Avatar
Its going to be "inperceptible" unless you put a gauge on it. This is NOT something your going to notice driving the car. It's not going to feel smother, better, faster....
Or...you could put one on, take a spin, put your hand on it: does it feel hot ? Yep, then your cooling the fluid.
From there you'll just have to trust that it is a fact that cooler fluid is better on a transmission over time than Superheated Fluid.
It aint Rocket Science Guys
Old Mar 18, 2003 | 01:51 PM
CLpower's Avatar
teh Senior Instigator
haven't you heard of the search function :P
Old Mar 18, 2003 | 01:54 PM
CLpower's Avatar
personally i'd stick w/ hayden or B&M, they are good names in the business and why buy something that's not up to par just to save 20$
Old Mar 19, 2003 | 01:20 AM
Allout's Avatar
Blown is Best
I would disagree. I've got the B&M 70264 (24,000 GVW) tranny cooler. I installed at around 40k miles. Did a flush of the system at the same time. My shifts are more crisp and consistent - even after hot runs. The transmission is more stable and I no longer feel differences in shifting when the transmission is hot. I'm expecting the true test durring the summer when temps get over 100 degrees F.
Old Mar 19, 2003 | 03:03 AM
Happy CL-S Pilot
The cooler may not be need at all..
The CLS uses the engine coolant to cool/warm the ATF.
Maybe no one mentioned this... but racing the CLS while engine coolant is still COLD is a mistake. The tranny will shift harder when the ATF is not warmed up. It may, actually, contribute to the failure of the tranny.. However, Acura has never acknowedged this fact.
Old Mar 19, 2003 | 10:54 PM
Allout's Avatar
Blown is Best
Stock tranny cooler does not pull off enough temp. Ever ask yourself why stock fluid goes dark - almost black? It's from excess heat cooking the fluid.
Your fear of fluid being too cold is not realistic. I agree that racing before your motor gets up to temp is a mistake. If you do, you get what you deserve. The B&M cooler has a self regulating orfice to regulate flow as needed. Comptech chose the 70255 as an independent solution for transmission cooling fully bypassing the stock radiator. I chose to put my cooler in series with the stock system for warranty issues.
Also think about this: When you set your car up to tow, you add a tranny cooler. Why? It's because you're putting an additional load on your drivetrain. If you drive aggressively, you're also putting an additional load on your drivetrain. Also, the difference between crank HP and wheel HP is HP loss (ENERGY). Where do you think that energy goes? It's transferred to the transmission fluid in the form of heat.
Think what you want but I've got real world experience on the benefits of the cooler. It's really not that complicated. Like Caddy said - it's not rocket science.
Old Mar 20, 2003 | 09:23 AM
SilverKnight's Avatar
Retired. Not available.
From my experience in Houston weather
No cooler: ATF got cooked, much darker than engine oil after ~5K miles.
with cooler: ATF still is pink after 12K+ mile.
Make your call.
Old Mar 20, 2003 | 12:15 PM
Juker008's Avatar
TRELOS
Allout,
Like u said u installed ur aftermarket cooler in series with ur stock cooler because of warranty issues. Would Acura really void the trannies if an aftermarket cooler were installed?
Is there more of a benifit if two afterarket coolers are installed in series than just simply only the aftermarket cooler, speaking in terms of taking out the factory one all together.
Juker008
Old Mar 20, 2003 | 12:33 PM
Juker008's Avatar
TRELOS
What do they mean when they talk about a remote filte. Are they stating that B&M has a seperate remote filter assembly that can be added to their tranny coolers?
Juker008
Old Mar 20, 2003 | 01:46 PM
FYI,
We do not have a dedicated tranny cooler. We have a tranny warmer that Acura hopes the warmer would use HOT coolant to cool ATF
Old Mar 21, 2003 | 12:34 AM
Allout's Avatar
Blown is Best
Originally posted by Juker008
Allout,
Juker008
My Acura Service Writer said that he would not void the warranty if I supplemented the stock cooler by adding the B&M. He would have a tough time keeping the warranty intact if I bypassed the stock cooler even if the independent cooler had a greater capacity - but he could not comment on how other dealerships would handle.
No benefit to going with two coolers. If you want additional cooling, depending on your environment and driving style, just get the bigger cooler. The 24,000GVW cooler I'm using is way overkill but what the heck.
If I was not concerned with the warranty, I would probably just use the B&M cooler independently like the Comptech design. The cooler independently has enough capacity to take good care of the tranny. Additionally, you would give more free cooling capacity to your engine by pulling that heat load off of the radiator.
You can add a tranny filter inline if you want but I'm not sure how much benefit. Not sure either way.
SilverKnight - I agree. My fluid is still as bright pink as new. Temps here haven't reached over 100 but I'm confident that the tranny won't see it with the cooler.
Old Mar 21, 2003 | 09:59 AM
Allout,
I installed the cooler at the beginning of Texas summer last year. Now, the fluid looks much better than newer fluild on a 02 CL-S (turning black, not even brown). I think yours will do just fine.
Old Mar 21, 2003 | 11:14 AM
CLpower's Avatar
nashua, a cooler is pretty much a must if you want these tranny's to last.
Old Apr 11, 2003 | 04:35 PM
DrDre1443's Avatar
112K and on 1st tranny!
do these coolers work on the 1st gen CL's? im about to get a 98 3.0CL and im very wary of trannies going out.....so where is the best place to get one and which one is the bigger one? i dont mind going overkill as long as it protects me!.........
I saw a Greek flag up above.....holla back!Greek over here in Charlotte NC
Old Apr 11, 2003 | 07:40 PM
CLpower's Avatar
yes dre, I have a first gen. Check over on that board. There are alot of us w/ them. You can get them anywhere basically.
Old Apr 11, 2003 | 10:19 PM
Allout's Avatar
Blown is Best
The B&M SuperCooler #70264 is their larger unit that's rated for 24,000 GVW. It provides more cooling than you'll ever need.
Old Apr 12, 2003 | 01:58 AM
Juker008's Avatar
TRELOS
Can't seem to fid the specs on the one that Nashau meantions:
http://www.v6accord.com/forums/show...&threadid=19479.
Is the B&M Supercooler #70264 cheaper than $150. That seems like someone is price gouging the cooler.
Juker008
Old Apr 12, 2003 | 11:25 AM
chef chris's Avatar
Homeless
Can we get some instructions on an install?
The warranty-intact install anyway.
Pham Alvan
May 18, 2021 06:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
Pham Alvan
Mar 16, 2016 09:17 AM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
