How 2 remove the 2 rotor screws ?
Old Aug 1, 2004 | 05:43 PM
916CL's Avatar
I was planning on switching my rotors but got to a problem with the 2 rotor screws. I tried to take them off but I just keeped stripping the screw. I think they are rusted on, is there another way to remove the screws.
thanks
Old Aug 1, 2004 | 05:46 PM
liloj's Avatar
i like orange juice
theres bit made for stripped screws..either that...or dremel a new slot and unscrew it that way and buy new screws
Old Aug 1, 2004 | 05:59 PM
Silverbulit40's Avatar
Enjoy the Ride
use one of these. Its very helpful
http://www.harborfreight.com/cpi/cta...emnumber=37530
Impact Screwdriver
Old Aug 1, 2004 | 06:15 PM
mattg's Avatar
Matt83076's Avatar
That happened to me. I just drilled the head off of the screw. Obviously you just need to be careful not to damage the rotor or anything.
Old Aug 1, 2004 | 06:29 PM
CleanCL's Avatar
yup, my friend and i had to drill the heads of the screw off. no big deal, didn't even replace the screws and everything is fine.
Old Aug 1, 2004 | 06:36 PM
4pumpedCL's Avatar
Honkey
impact screw drive is the way to go
Old Aug 1, 2004 | 07:56 PM
Allout's Avatar
Blown is Best
Did mine yesterday. I didn't have an impact screwdriver so I gripped the handle of a Craftsman screwdriver with a large pair of vise grip pliers, leanded into it and they popped.
Old Aug 1, 2004 | 08:09 PM
fuzzy02CLS's Avatar
I have that one. It's real handy. It's a bit arkward to use but gets the job done. I haven't used it on the rotors but other things I have.
Old Aug 1, 2004 | 09:04 PM
Red-CL's Avatar
Doin' da crack shuffle
Worked for me.
Old Aug 1, 2004 | 09:46 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
how about a 3/8 ractchet with screw driver bit?
Old Aug 1, 2004 | 10:43 PM
MethodRN's Avatar
HELLLLLLOOOOOO NURSE!!!!!
Had the same prob a year ago. Had an impact driver but bit shattered on last screw and parts were stuck in slots. Could not use taps cause of the bits stuck in slots. Luckily neighbor was handy with drill and chisseled out notches that we then used a flat head and a hammer on. That one damn POS screw cost me 1hour when it took me 1 hour to change pads and lines on 3 corners and 1 rotor on one side. Does anyone know why those screws are there? Other cars I've worked on brakes didn't have those.
Old Aug 2, 2004 | 05:34 PM
ModAddict's Avatar
I have not done this myself yet, but read somewhere, to reinstall the lugnuts and torque them a bit and the screws will back right out easily.
Old Aug 5, 2004 | 02:46 PM
Happy CL-S Pilot
I started the isntall and faced the same problem. Even with the use of the imapct screw driver the scews are stuck. I risked stripping the head of the screws so I Aborted the installation and put back the pads and caliper. I used this penatrating liquid and it did not help on the screws...
Why in the world Acura has those scews on the rotors, other cars like nissan they have no screws!
To my amazing the front pads have some 33 kmiles and are only 40-50% worn. I may be able to drive to 100kmiles with those pads.
There was a lot of rust everywhere and the virtually no grease what so ever!....
Recommendation if you have squeaking brakes and you did not replace the pads for a long time, remove the pads and apply a new coat of grease and re-install.
Now, I may either sell the new rotors and pads or pay some $120 and let a Pro tech at the dealer do it for me...
Nashua.
Old Aug 5, 2004 | 03:18 PM
rbf351's Avatar
Registered User
The screws are there to hold the rotor on when its on the assembly line, otherwise they serve no purpose and you can toss them after you remove them
Old Aug 5, 2004 | 04:57 PM
ChadT's Avatar
Spectacular Aroma About
All you have to do is tighten the lug nuts down on the rotors to relieve the tension and those screws will almost turn by hand.
Old Aug 5, 2004 | 05:37 PM
ModAddict's Avatar
Old Aug 5, 2004 | 06:06 PM
ChadT's Avatar
Time for another
Old Aug 5, 2004 | 06:42 PM
ModAddict's Avatar
Originally Posted by ChadT
Time for another
When I said it, it was heresay. Sounds like yours was the voice of experience!
Old Aug 12, 2004 | 09:02 AM
Happy CL-S Pilot
Today, my CLS is at the local honda dealer for the rotors/pads installation: cost is $120 at 4hrs @ $30/hr for an employee cost.
Man... that is a lot, my Trusted Tech said he does the job in less than 2hrs for actual time!
Nashua.
Nashua.
Old Aug 12, 2004 | 09:18 AM
CBR1100XX's Avatar
Way Fast Whitey
I have done several brake jobs on my own cars, but not my Hondas. I hate those damn screws. I feel the same way about the wheel holding the rotor in place. I have tried to use one of the impact screw drivers with little success.
Old Aug 12, 2004 | 09:58 AM
ModAddict's Avatar
Old Aug 12, 2004 | 11:48 AM
Happy CL-S Pilot
man.. the work was completed in around 60-75 mins max and I was charged for 4hrs! And the tech was like some 20 yrs old guy....
What is up with that!
Old Aug 12, 2004 | 03:07 PM
Smitty's Avatar
When you go to put the screws back in... or if you buy new flat head screws.. PUT ANTI-SEIZE COMPOUND on the threads and screw them in... you will NEVER HAVE a hard time again..
Old Aug 12, 2004 | 03:48 PM
Smitty's Avatar
Time to take this to the Frequently Asked Questions & Common Topics Section.
IBTM
Old Jan 16, 2006 | 06:09 PM
03_CLS_6sp's Avatar
Thank you so much for the tip, I tightened three lugs down, and those damn screws came off pretty easily.
I needed a pipe to bust loose the caliper bolts too. Damn.
It's way way way better/easier than my old '95 Accord...
Old Jan 17, 2006 | 08:31 AM
erishe69's Avatar
I had a hell of a time replacing the rotors on my '98 CL. I took it to a buddy of mine who races Chevy's. All he did was take a propane torch to the bolts for about 15 secs and they popped off.
Old Jan 17, 2006 | 11:08 AM
Mike01s's Avatar
make sure you use a #3 phillips bit not the common #2
Old Jan 17, 2006 | 10:51 PM
Titand19's Avatar
East Coast Boost.!
drill it out, you don't need'em anyway
Old Jan 18, 2006 | 02:25 AM
rtatsutani's Avatar
Never had a clean run
Old Jan 18, 2006 | 02:35 AM
harminder247's Avatar
:( Harminder Is Lost In
i did mines this past sunday, and no joke took me about 15 mins on each side, they came off VERY EASY, i used a cordless drill to remove the screws, came out widout a problem, took me about 10 mins puttin em on, all this cost me was 16 bucks which wasnt bad at all
lanechanger
Oct 13, 2015 10:56 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
StevieB1503
ILX
Oct 8, 2015 04:52 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
Brandle34
Sep 23, 2015 07:20 PM
