Help! UR Pulley problem
Old Nov 15, 2009 | 02:59 PM
tnobori1's Avatar
Missing my
I ordered an Unorthodox Racing stock diameter pulley (Part # 02.06.110) from ebay, but the guy installing it says it is about half the size of my OEM pulley. Does that part number sound like I was sent the underdrive pulley? WTF?! Any help would be very helpful! I know it sounds ridiculous, but is there a size difference between OEM and the "stock diameter" UR pulley?
Old Nov 15, 2009 | 03:58 PM
friesm2000's Avatar
B A N N E D
try checking UR website
Old Nov 15, 2009 | 04:24 PM
tnobori1's Avatar
Missing my
I did, it isn't as helpful as you would think. I googled the part number and found an instruction manual, which seems to imply it's the underdrive pulley. Whatever, I wasn't really wanting to underdrive my whole system, but F it! I don't want to deal with the hassle of sending it back and waiting another 2 weeks to get this part on. Guess I'll just have to live with more power!
Old Nov 15, 2009 | 04:28 PM
Rajca's Avatar
wham bam thank you ma'am
u got the underdrive pulley. i got the stock size ur pulley on my cl right now. let me know if u want it
Old Nov 15, 2009 | 05:39 PM
tnobori1's Avatar
Missing my
Figures... Oh well, I already bought the gates belts and it is being installed as we speak. I'm just hoping I don't have problems with my ac or alternator (even though everyone seems to have had good luck so far).
Old Nov 15, 2009 | 06:20 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
You wont have any issues.Thats the pulley I have I think.
share your experiance when you get on it from a stop.I'm willing to bet you will be happy you added the pulley.
That piece work out for you ?
Old Nov 15, 2009 | 09:00 PM
fuzzy02CLS's Avatar
X2
you won't have a problem stop worrying & enjoy your car.
Old Nov 16, 2009 | 07:48 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
yea the pulley is a fool proof mod IMHO
can NOT screw it up,
You WILL feel the POWA!!!!
Old Nov 16, 2009 | 11:14 AM
Excelerate's Avatar
Former Sponsor
The UR Ultra S Underdrive pulley is part # 020611002. It is fine for all vehicles except those with stereo systems over 600 watts RMS and/or superchargers.
The UR Ultra SC Stock Diameter pulley is part # 020611012. It is fine for all vehicle and will not underdrive the accessories. We are the exclusive distributor for the stock diameter pulley since UR has discontinued it and it is manufactured solely for us so that we can still provide it for the AZ community.
Old Nov 16, 2009 | 02:04 PM
tnobori1's Avatar
Missing my
Thanks everyone! Sorry for the freak out
I had my water pump, timing belt, crank seal, cam seal, and belts changed. I also had the valves adjusted, new tranny fluid put in, and a coolant flush. Apparently all the valves were way off. Add the fact that i seafoamed the car about 200 miles ago and had the new pulley installed, I was SUPER excited to drive it home last night! It was about 45 degrees out and I took the opportunity to let it rip!
The car runs better than it ever has and when I hit WOT... !! I couldn't be happier!! Now I'm just looking for reasons to take the car out... "sure honey I'll go to the store, sure I'll go to the bank, sure I'll go get dinner!" LOL, it's like I'm 16 again.
Richard, I haven't had the chance to install the ballast yet. Hopefully Wednesday.
Old Nov 16, 2009 | 02:19 PM
O' I'll go......I do the same thing to listen to my stereo.
Old Nov 16, 2009 | 03:55 PM
stlswagger's Avatar
Not good for people with more than 600 watts huh? I just put my two 12's in and have 600 watts RMS going to each sub. So should I get a new alternator because I do want these pulley's for my car.
Old Nov 16, 2009 | 04:18 PM
civicdrivr's Avatar
You can get the stock sized lightweight pulleys.
The underdrive pullies won't work too well with a large stereo due to amperage draws.
friesm2000's Avatar
B A N N E D
should be fine, do you ever listen to your subs at full volume???, and if you are showing off with them at full volume, just push the accelerater a little so it is at a high idle (like 1500-2000)
Old Nov 16, 2009 | 04:30 PM
I run 2 1600w rms amps with the underdrive ones and It draws bad.
You have to be carefull with your volume or you amps will see the magic smoke if the current is not there for them to pull from.
If I run only 1 it's fine.
Old Nov 16, 2009 | 08:14 PM
stlswagger's Avatar
I'm going to try installing a cap by this weekend. I think on my way home my amp was overheating. I have it installed where my spare used to be and it kept going on and off after beating it up on the way home. I got home and lifted that cover and it was pretty hot in there. Today it seemed fine but volume wasn't all the way up.
Old Nov 16, 2009 | 08:19 PM
friesm2000's Avatar
B A N N E D
do the amps have enough air flow to get rid of the heat
Old Nov 16, 2009 | 08:25 PM
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
I am pushing a bit more than 600 watts and have no problems.
Old Nov 16, 2009 | 08:45 PM
Amps over heating is from running to low impedence or you need to turn down the gain.
To all that don't know the gain is not a volume its to match the output from the HU or line converter. If you have to much gain the music waves flaten at the peak and the amps signal will be cliped.This will over heat your amp.
And too much gain will also smoke subs that you wonder how the hell did I smoke 800w subs with a 600w amp.
I'm sure your getting enough current for your needs now.
Be sure to tune your amp properly.
Old Nov 18, 2009 | 12:25 PM
stlswagger's Avatar
Fixing my heat issue this weekend. Man I'm a thread jacker now lol. Sorry dude!
I took out my spare and put the amp in there but will be rebuilding that floor cover this weekend.
Old Nov 18, 2009 | 01:19 PM
it's funny, the sound system is one of the few things I don't want to upgrade.
BASE gives you rattles eventually also, and we don't get along very well.
LOL my buddy had a Jimmy and his 3 JL 12s were so loud the door pins came out and then his door ended up dangling to the point it wouldn't even line up with the door latch and then needed me to fix it.
that's what I call PUMPIN tunes :-)
Old Nov 19, 2009 | 03:20 PM
Excelerate's Avatar
Former Sponsor
If you a stereo system you should get the stock diameter pulley so it does not underdrive the accessories:
http://store.excelerateperformance.c.../i-291888.aspx
Old Nov 19, 2009 | 03:43 PM
i would have to agree with you there... you will eat through batteries as I did on my ford probe with the underdrive set up and a system. lights dim, a/c slows down, actually it was so bad the a/c cut out untill you hit 1200rpm cause there literally wasn't enough power.... it's just a PITA to think u created the problem. That's the real killer
Old Nov 19, 2009 | 03:58 PM
friesm2000's Avatar
B A N N E D
it was a ford what did you expect
Old Nov 19, 2009 | 04:16 PM
F.O.R.D stands for
found on road dead
fix or repair daily
lol i found that out AFTER i got it thank you very much. that fucking thing was the lemon of lemons. When I blew the trans on my CL I was like, tru, expected... and i could still drive it to the guy who fixed it.. so it's never left me hanging. UNLIKE the ford, that was it's specialty
My probe, would make me use my CAA card 2-3time a YEAR.. and i was still fixing shit on my own time whenever I could..
Unbelievable. I thought I could Beat the car's problem, but no... it beat my wallet and maxed my credit card out..... yikes
Old Nov 19, 2009 | 04:18 PM
oh did i mention my motor threw a piston! 11hrs after getting it.?? i grabbed my buddy to show him the whip... we were young and in highschool so this thing was COOL.. and modded heavily. and yea
bolt came loose that connects the rod to the piston... u know the rest... onto motor 2
Old Nov 19, 2009 | 04:30 PM
friesm2000's Avatar
B A N N E D
F.O.R.D stands for
found on road dead
fix or repair daily
what's CAA then is it some stupid ian thing
, only thing domestic i would buy would be a diesel pickup, or a sports car (like a corvette) cause for the diesel no asian company offers one here
and the corvette, cause it is really fast, especially once you put a s/c on it
Old Nov 19, 2009 | 04:42 PM
only one sports car now in my mind.... skyline GTR.
Watch Top Gears episode on it and u will hate everything else.
It placed in the top 10 ALL TIME (i think $6 or 7) for their track test. above the bugatti Veyron.
Given it NOT a track car at all but, it has an extra 550HP and got SPANKED.
No american car will ever be able to handle the GTR or w/e comes after it... HA that'll be amazing to see
Old Nov 20, 2009 | 11:37 AM
civicdrivr's Avatar
A sports car isnt a sports car unless you can row your own gears.
In my mind at least.
Old Nov 20, 2009 | 11:49 AM
"row ur own gears" ?? u lost me there
Old Nov 20, 2009 | 12:08 PM
civicdrivr's Avatar
Old Nov 20, 2009 | 01:02 PM
StreetKA's Avatar
we have subaru legacy diesel
and
x2 for civic driver about GTR - its an automatic
Old Nov 20, 2009 | 01:38 PM
wtf gtr is auto??? awwww fakkkkkk. I feel like a tool now (shat ap! lol)
I thought it'd be obvious they'd offer it..
ah i bet they will eventually. Just gonna have to wait it out
Old Nov 20, 2009 | 02:50 PM
friesm2000's Avatar
B A N N E D
it is a performance auto though, but still an auto
Old Nov 20, 2009 | 02:53 PM
friesm2000's Avatar
B A N N E D
from where???
where???
where???
where???
i want one (diesels are so sweet)
Old Nov 20, 2009 | 02:59 PM
friesm2000's Avatar
B A N N E D
from where???
where???
where???
where???
stupid edit time limit
but anyways i thought they had not come out yet, i know they were going to at some point though
Old Nov 20, 2009 | 04:16 PM
i know auto now is faster but i don't care, speed and the driving experience, is just not the same as when you literally ARE the car.
fuck i miss shifting like a ninja, and pulling away from everyone off the line. whata great feeling that was... and will be one day again.
Old Nov 20, 2009 | 05:10 PM
civicdrivr's Avatar
If you can call an auto "performance", sure.
from where???
where???
where???
where???
Ive read reviews that Subarus diesels suck.
Old Nov 20, 2009 | 05:18 PM
friesm2000's Avatar
B A N N E D
from where???
where???
where???
where???
proably should have put the performance in red text
and you can't expect every thing to be perfect when it first comes out, give them a couple of years to refine it
Old Nov 20, 2009 | 06:09 PM
civicdrivr's Avatar
C'mon, its been out for 2 years!!! Why doesnt it make 400hp, 1200tq and spew rainbows and lollipops from the exhaust!!
