HELP - speedometer problems
Old Jul 9, 2003 | 11:06 AM
ch1276's Avatar
Today my speedometer stopped working, it said I was driving at 0 MPH and then it would jump to around 40 and get stuck there
any ideas what this could be? All the other gauges work fine.....could it be a fuse?
Old Jul 9, 2003 | 07:20 PM
kensteele's Avatar
If you speedometer is broken, better get it fixed quick.
Last speedo I had broken, my car got certified which means there was no way to tell how many miles it had on it when I sold it. Not good.
Old Jul 9, 2003 | 10:38 PM
Jens H.'s Avatar
retired
I see you have reverse indiglo gauges ,is it possible the overlay has come loose a bit and is interfering with the operation of the needle ?
Is the check engine lite on? If it is the speed sensor in the gear box i s dead or on it's way out.If not the speedo could just simply have failed .
Jens
Old Jul 10, 2003 | 07:04 AM
ch1276's Avatar
Jens, it doesn't look like the overlay has come loose...last night when i left work it worked fine, go figure
the check engine light is not on either...I actually have an appointment to bring it in to see you on Monday so I will see you then
chris
Old Jul 16, 2003 | 09:03 AM
ch1276's Avatar
Jens as always thanks to you and PAA
Old Jul 16, 2003 | 11:33 AM
Jens H.'s Avatar
retired
My pleasure, thank you for your business .
Jens
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
