HELP!!! rotor screw is f'd!
My impact screwdriver bit broke into the rotor screw!!!
I purchased some rotoras from Excelerate and I tried to install them this weekend. I used my impact screwdriver to remove the 2 screws holding the rotors. The screw was on there so tight, that it broke the impact screwdriver bit...INSIDE the screw head.
WTF do i do!?! I tried to drill out the screw...but the hardened bit (that's jammed inside the screw head) is preventing my drill from really being able to work...
Originally Posted by PMGCamaro
You could use a rotary cut-off wheel to cut a notch into the head of the screw. Then just use the flat head bit with you impact screwdriver to remove the screw
Well...it's kinda fast...
I agree with CleanCL, a screw extraction bit is your best bet. They sell 'em at Sears and most hardware stores...they saved me lots of time and effort. Once removed there's no need to replace it. It doesn't really serve a purpose other than holding the rotor in place when installing new ones.
ahh, that's right... extractor bit
taking a ball peen hammer and placing it on the screw(rounded end), then hitting it with another hammer first will make them come out much easier.
666 Speed
1 Post
Originally Posted by Allout
I used a center punch and hammer to drive the screw counterclockwise. I was able to loosen and remove the screw using this method.
That or a chisel.. Thats what I did..
Gonna cost to catch up
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
