Help guys, I screwed up installing Polargs..
Stealth Bomber
Well the driver's side Polargs when in fine but when I tried to put the passenger one in, it was a tight fit and the bulb broke in the housing. Luckily I bought 3, just incase one burnt out. But is there anyway to disattach the housing, so i can shake out some remnants of the bulb.
Thanks guys, they look great, not really functional but look good
Thanks for your help,
Steve
2001 Black CL-S
Spoiler
Trunk Mat
Compustar Alarm/Remote Start
Polarg M6s
20 % Tints all the way around
[This message has been edited by BLK CLS (edited 05-08-2001).]
Steve
2001 Black CL-S
Spoiler
Trunk Mat
Polarg M6s
Yes. There is one screw that hold the raod lamp together. I used a small ass philips screwdriver to remove the screw. After removing the screw, there is a latch you press in. Then you can remove the whole housing. I too broke one of the polarg bulbs trying to fit it in. It took a good 20minites of cleaning to completely remove the littl eglass pieces.
Spiro
Black/Black 2001 CL-S
RED AEM CAI
Polarg M6 Roadlamps
Spiro
RED AEM CAI
Polarg M6 Roadlamps
Ambidextrous Masturbator
It is easy to detach the road lamp from the bumper. Just lossen the screw and release the plastic tab. It will pop right out. In the FAQ section, there are pics of this process (not to change the bulbs, but to do something else.. I can't remember what). It is really easy. I changed my bulbs in 10 minutes for both using this method.
Hope this helps.
edit - here are those pics I was talking about - http://www.acura-cl.com/ubb/Archives...-4-000080.html
Sid Vicious
2001 CL Type S w/ NAV in Silver | Wheel Locks | Front Plate (Mounted in the Trunk) | Mobil 1 | Polarg M6 NEW! |
1992 Ford Ranger XLT in Silver | F-150 Springs | 3" Body Lift | K&N Filter | Flowmaster Exhaust
[This message has been edited by SidVicious (edited 05-08-2001).]
Hope this helps.
Sid Vicious
cycdaniel
12-17-2019 10:58 AM
Skirmich
09-15-2015 06:41 PM
