Help Aiming Headlights
Old Dec 23, 2008 | 02:21 PM
madmuzik09's Avatar
Waits for Shakira in his
some how my headlights are not leveled does any one have a DIY for adjusting their headlights and are they suppose to be centered or pointing to the groundish pics will help Thank you
Old Dec 23, 2008 | 06:22 PM
nf3d0149ab's Avatar
Here is some info. to resolve your inquiry. Good luck.
Good Reference Thread
https://acurazine.com/forums/showthr...=aim+headlight
PDF Guide
http://www.coolbulbs.com/HID-VISUAL-...-PROCEDURE.pdf
Member's Notes
Originally Posted by DPOLICH
Looking down from the top behind each headlight assembly is an adjustment mechanism.
This looks like teeth or gears that are then rotated by using a phillips screwdriver when
turning the teeth with the phillips head. This is the adjustment for height. There is another adjustment mechanism for side to side. This is not necessary after lowering.
Originally Posted by Shawn S
LOOK FOR THIS
INSERT PHILLIPS SCREWDRIVER & ADJUST AWAY
Old Dec 23, 2008 | 06:29 PM
CL-Slick's Avatar
Chillin' in my trailer
Going to tackle this this week.
Old Dec 23, 2008 | 06:53 PM
madmuzik09's Avatar
thanks alot man exactly what i needed but careful when doing this cause i had to do the radio code after for somereason but i kno the passenger side is supposed to be higher than the driver side but mine looks like the passenger side is brighter even tho the driver side is newer than the other what shud i level it to be high or low
Old Dec 23, 2008 | 07:07 PM
nf3d0149ab's Avatar
Your welcome.
You said your two HID's are inconsistent...You want to level the brightness?
To be honest...I am not sure if it's possible.
Maybe there is a way to tweak it but with all equipment being the same...I wouldn't know how.
I'll keep looking though...
Old Dec 23, 2008 | 07:12 PM
madmuzik09's Avatar
no there both te same but because of the way one is higer than the other one it looks different but shud i level them to look the same or shud one be higher than the other how do ur look
Old Dec 23, 2008 | 07:57 PM
nf3d0149ab's Avatar
Mine are parallel from what I can see...
That was the first time I had heard of aiming one higher than the other.
Old Dec 23, 2008 | 09:17 PM
Garkon's Avatar
It is normal for the passenger side to be slightly higher than the driver(so you can see the side of the road, but not blind oncoming drivers). On a nice level ground, the cutoff of my lights as they reach for the horizon looks like this:
_______________/'''''''''''''''''''''''''''''''''''''''''''''''''' ' Well, sort of. You get the idea.
Old Dec 24, 2008 | 02:09 PM
madmuzik09's Avatar
mine are way off
Old Dec 26, 2008 | 07:20 PM
poisx7's Avatar
mine have always beign leveled the same.
maybe I shud have the slant look but I have never had any problems even on long trips ..........so >>>>>>>> I dont see d need 2 change now.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
