Help after resetting ECU, Stereo problems now
so after resetting my ECU by disconnecting the batter, then letting my car idle fer a bit, my stereo now SUCKS for some weird reason. i turned the bass and treble back up, but for some strange reasaon there isnt that much bass anymore. it's as if the "BASS BOOST" got turned off.
is there something i missed or forgot to do?
if anything, i have to take my car back to the dealership to check that out, but i wanted to check with you guys first.
thanks all
thanks all
Originally posted by amirsafdari:
<STRONG>first, check if both the rear speakers are working...</STRONG>
it also crackles alot at higher volumes too. almost as if that electronic stuff to keep it sounding good isnt working.
it must have shorted the amp or something when i re-connected the battery.
Originally posted by TypeSDragoon:
<STRONG>
all the speakers are working, i just went out and made sure.
it must have shorted the amp or something when i re-connected the battery.</STRONG>
<STRONG>
everything IS turned up.
it mostly sounds like that electric stuff that turns downt the bass when you turn up the volume isnt working, and it just totally sounds like shit now only AFTER i disconnected the battery.
it sounded SO good for many months until i reset the ECU.
Well, this is wat I think tho..... After you pull the battery to reset the ECU... Accord to theory, ECU has nothing to do with your stereo system, none at all! If you say after resetting your ECU, your car have rough idle, then it has some connections, but stereo, NONE! so I would check out the fues that for the stereo, like amp, sub, etc... They all should have a little fues near the battery terminal, check that, maybe when you pull it, it blew the fues.... check those!
SidhuSaaB
May 30, 2020 12:40 AM
cycdaniel
Dec 17, 2019 10:58 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
