HELMS HELP!!! random misfire all 6 cylinders... plus
Old Apr 20, 2005 | 06:25 AM
  #41
typeR's Avatar
Originally Posted by 1killercls
Results???
phase two: disconnect the cat and or swap out the ECU
Old Apr 20, 2005 | 03:30 PM
  #42
1killercls's Avatar
GEEZER
If ya need anything, don't hesitate to call.
Old Apr 20, 2005 | 06:14 PM
  #43
typeR's Avatar
CAT un bolted it and this car ripped the tires right off her again woo hoo...and it might even be under warranty...the tech thinks he remebers seeing a warranty extension letter on these cars? anyone know?
Old Apr 20, 2005 | 07:56 PM
  #44
1killercls's Avatar
GEEZER
:killer:
Old Apr 20, 2005 | 08:34 PM
  #45
RUF87's Avatar
Lead Footed
Here's what I've seen on the know issues for the TL:
Bulletins for 2002 Acura 3.2TL TYPE S V6-3210cc 3.2L SOHC
Safety Recalls
TSB Number Issue Date TSB Title 01-020 MAY 01 Recall - Defective Front Seat Belt Assemblies
01-019 MAY 01 Recall - Driver Window Control Unit Water Damage
General Recalls
TSB Number Issue Date TSB Title 03-030 OCT 03 Campaign - Engine Timing Belt Tensioner Replacement
03-017 SEP 03 Campaign - PCM/Fuel Pressure Regulator Update
Service Bulletins
TSB Number Issue Date TSB Title 04-008 MAR 04 Navigation System - Operational Malfunctions
01-041 FEB 04 Engine - V6 Engine Oil Leaks
04-004 FEB 04 Computers/Controls - HIM Module Updating
01-026 JAN 04 Engine Controls - ECM/PCM Reprogramming
00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
03-029 OCT 03 Brakes - Brake System Lamp Comes ON/Goes Off
03-028 OCT 03 Navigation System - Incorrectly Displays Phone Numbers
91-050 SEP 03 Interior - Seat Belt(s) Slow to Retract
03-015 AUG 03 Audio System - Remote Controls Don't Work Properly
98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
97-040 MAY 03 Keyless Entry - Description/Identification/Programming
01-017 MAY 03 Brakes - Pedal/Steering Wheel Vibrate When Braking
00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
03-006 MAR 03 Engine Controls - Idle Speed Inspection
03-003 FEB 03 Interior - Power Seat Rail Synchronization Update
02-020 AUG 02 Air Bag System - Occupant Position Sensor Initialization
02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
02-006 MAR 02 Front Seat Back Panel - Loose/Detached
02-005 FEB 02 Emissions - EVAP System Testing and Diagnostics
96-025 DEC 01 Navigation System - Component Exchange Program
99-041 NOV 01 Navigation System/A/C - Operation/Testing
01-010 FEB 01 TQI - New Features and Unique Inspection Procedures
Old Apr 20, 2005 | 08:36 PM
  #46
RUF87's Avatar
Lead Footed
Actually look at this link.
http://www.alldata.com/recall/make/Acura.html
There are some interesting ones in here . . . like the oil leak and the ECM reporgramming . . . which I didn't think was possible on our cars.
Ruf
Old Apr 20, 2005 | 10:14 PM
  #47
SCTL-SS's Avatar
13.68 @ 102.56
Glad to hear that it at least is starting to look more encouraging.
Old Apr 21, 2005 | 06:52 AM
  #48
sohfast94's Avatar
Cat Removal...
Old Dec 30, 2006 | 09:54 PM
  #49
njzprettyboy's Avatar
what was thee problem typer, did you ever get it fixed?
Old Jan 2, 2007 | 08:39 AM
  #50
phipark's Avatar
Not Asian
the cat
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
jmaxima03
Sep 27, 2015 10:22 AM
kencepeda
Sep 26, 2015 05:13 PM
holografique
Sep 1, 2015 07:54 PM
