Headlight Thread #1,673
Old Nov 22, 2009 | 05:11 PM
tnobori1's Avatar
Missing my
Yep, another headlight thread. I'm 90% this is a new problem though. I have been having headlight problems for about 18 months now. Standard issues with the flickering and turning off of the lights. First the driver side light was out, but two months later the passenger side went out.
Initially, I replaced the bulbs, only to find out it was a different and much more expensive ballast problem. The lights (or just one) would come on for a few seconds, then turn off. If I flicked the switch on and off a few times at least one of the lights would turn on for the trip. They eventually both stopped working altogether and I drove with my high beams for like a week. Instead of spending $800 at the stealership, I bought two used ones on CL from some guy in TX. Installed them both and found that both were faulty, though after reinstalling one of my old ones, it was working on the passenger side (after some flickering of the switch).
I just bought another ballast from an Aziner and installed it today. Put it on, replaced both fuses and cleaned the contacts of the fuses and the relays then it fired right up... for 3 seconds. I then flickered the switch on and off and both lights stayed on.
WTF??!!!!!!!!!! The odds that all 3 were faulty is SUPER unlikely, plus the member I bought it from is a trusted guy on this site. Any advice? Should I replace the relays? Checked every single fuse in the car and everything is fine. SO FRUSTRATING!! Every common issue in our cars has some unusual variation in my car.
Old Nov 22, 2009 | 07:30 PM
tnobori1's Avatar
Missing my
^ Bump! 6 views! I should have chosen a different title, but I really need some advice please.
Old Nov 22, 2009 | 07:35 PM
zac's Avatar
zac
^ Yes, you got 6 views, or 8 or however many. Out of those views, I doubt they could give you accurate, helpful advice. Including me, sorry I know nothing about electrical.
Old Nov 22, 2009 | 07:46 PM
tnobori1's Avatar
Missing my
No, I just meant that there were so few views... I should have put "naked chicks" or "HELP" instead of getting cute with it. It was my fault, I wasn't pointing fingers.
Old Nov 22, 2009 | 08:15 PM
zac's Avatar
zac
Haha, my bad. Yea see if a mod could add XXXPORNXXX to the title
Old Nov 22, 2009 | 08:31 PM
friesm2000's Avatar
B A N N E D
you can still get bad parts even if it was from the dealer
Old Nov 22, 2009 | 08:40 PM
tnobori1's Avatar
Missing my
True, it's just unlikely that 3 consecutive used parts would be faulty, especially from trusted members. Besides, the part seems to be working, but why does it need to have the switch flickered on and off? Could it be a relay?
Old Nov 22, 2009 | 09:48 PM
civicdrivr's Avatar
Pick up one of those $60 HID kits from the Black Market and install those ballasts. See if that helps. Seeing as how these ballasts are notorious for these problems, I wouldnt be surprised if all 3 were fried.
Sidenote - Youre from the bay area, keep an eye on your car. There seems to be a theft ring there involving CLs.
Old Nov 22, 2009 | 10:01 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
The one you got from me,Did that one work for you ?
That one was not faulty for sure. PM'n
Old Nov 22, 2009 | 11:01 PM
BT5150's Avatar
I'd second what civicdrvr says, just get one of the aftermarket HID kits and put that in. You'll have new ballasts and bulbs. They have come down amazingly low in price, some places have them for $60. If you are concerned about reliability, some of the sites sell "name brand" gear like Philips for a little more, but from what I've read, even the cheaper kits are reliable.
Old Nov 22, 2009 | 11:45 PM
civicdrivr's Avatar
One of our vendors:
https://acurazine.com/forums/sponsored-sales-group-buys-10/hid-special-%2460-shipped-acurazine-members-723872/
$60 shipped gets you new ballasts and bulbs with a 2 year warranty.
Old Nov 23, 2009 | 08:06 AM
MrFluffy's Avatar
To many cars in my garage
If you dont think its a balast issue I would pick up a volt meter and test the power going into the balast.
Also if you want to see if its a wiring problemcarfully touch the two leads of the balast directly to a battery and see if it flickers if it still flickers its a ballast issue if not it could be wiring issue but at least you will know
But I agree with civicdrivr pick up some after market balast
Old Nov 23, 2009 | 01:15 PM
tnobori1's Avatar
Missing my
Ok, I'll try the volt meter and wire check. Richard, it's not the ballast. Idk what else to try, but I guess I'll wait and see what the VM says. Thanks for the feedback.
As for after market ballasts, I have two Phillips ballasts, but I haven't felt like figuring out rewiring and rigging up a bracket. We'll see.
Old Nov 23, 2009 | 01:17 PM
tnobori1's Avatar
Missing my
Yeah, I saw the other post. I just moved out to Discovery Bay... still Bay Area, but pretty far from the other thefts.
Old Nov 23, 2009 | 03:02 PM
MrFluffy's Avatar
If you got an after market ballast it would maybe take an extra 5 minutes to install as compared to OEM if you need instruction on how to do it there is a thread also you can IM me and I can help you out
Good luck
Old Nov 23, 2009 | 07:57 PM
tnobori1's Avatar
Missing my
Good luck
I've seen the thread, just seemed like a lot more work... I know the next time one goes out for good, I will be doing the conversion. Fucking Acura ballasts!
Old Nov 23, 2009 | 08:01 PM
MrFluffy's Avatar
I really dont think that anyones ballast is perfected and to get 6
years out of one is pretty average , aftermarket or OEM
Old Nov 23, 2009 | 10:29 PM
tnobori1's Avatar
Missing my
Fair enough, but you would think waterproofing would be high on the list of desirables when designing electrical parts! Either way, I'm pissed at Acura for a 2 year navigation issue in my wife's MDX that they may or may not fix. Now every little issue is their fault!!
Old Nov 23, 2009 | 11:51 PM
MrFluffy's Avatar
I agree
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
rockyboy
Sep 29, 2015 12:05 AM
AmplifiedDetails
Sep 24, 2015 02:55 PM
STL TL-S
Sep 23, 2015 08:52 PM
