Headlight Out
Old Nov 20, 2006 | 12:34 PM
123456SPEED's Avatar
CLS 6MT Navi
Headlight Out
My right headlight is out, just flickers faintly. And my high beams are glowing faintly. Can the HID problem effect the hi beams too? Bad timing as I'm going out of town for the holiday and don't think I can get it fixed beforehand.
I did have roadlamps wired in a year ago at a reputable independent shop that specializes on Hondas/Acuras. Do you think the dealer will hassle me on the addon roadlamps, could it be connected to this problem? Roadlamps are still working.
Old Nov 20, 2006 | 01:11 PM
AcuracltypeS03's Avatar
if its the blub then i got one brand new too..
Old Nov 20, 2006 | 01:23 PM
RaviNJCLs's Avatar
If it's the bulb, I don't think they will give you a tough time. Even if it's the ballast, I don't think they should give you a problem.
Old Nov 20, 2006 | 01:38 PM
fuzzy02CLS's Avatar
well if your high beams are acting up, those are not tied into the HID's. So there may be a wire loose, or a grounding problem. Or maybe a battery voltage issue.
Old Nov 20, 2006 | 02:18 PM
CLS 6MT Navi
thanks guys, went to the dealer on lunch break, they said it was a bad fuse. lights are working fine now, but now I hear a weird buzzing noise in the car now, radio was off.
and yesterday the car died on me while I was waiting in traffic. I thought I had killed it with the clutch maybe, now I'm not sure what happened.
The battery is about a year old. I have never added any electricals to the car except the roadlamps a year ago.
Planning to go out of town, I need to check it out some more.
Old Nov 20, 2006 | 02:40 PM
fuzzy02CLS's Avatar
What kind of battery?
These are symptoms of a battery going bad.
Old Nov 20, 2006 | 02:49 PM
RaviNJCLs's Avatar
But a year seems to be a very short life span for a battery. Any chance your alternator is fucked and not re-charging the battery.
Old Nov 20, 2006 | 02:57 PM
cltypeSLOW's Avatar
Don't Mess With Texas
my headlights were doing the same thing when my OEM battery took a dump...i changed the batt and everything went back to normal.
Old Nov 20, 2006 | 03:20 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
OEM batteries suck. I had two die on me within 6 months, and both were brand new. It all depends on the climate where you live. More humidity will shorten the life of a battery.
Old Nov 20, 2006 | 03:38 PM
fuzzy02CLS's Avatar
& heat. TX had a hot summer....
Old Nov 20, 2006 | 03:41 PM
You're tellin' me
Old Nov 20, 2006 | 03:49 PM
cltypeSLOW's Avatar
123456 this is a bit offtopic, but are you interested in getting together next time kevin and i do a photoshoot and some driving up 2222?
Old Nov 21, 2006 | 01:29 AM
Corrosion's Avatar
White as night.
Wow.. what a coincidence, mine started doing the EXACT same thing two days ago, also a bad fuse... Same year CL too.
Old Nov 21, 2006 | 01:40 AM
Corrosion's Avatar
White as night.
Ok, problem #2, I put a Pep Boys fuse in and now the left (my left one originally had the aforementioned problem) headlight is not the same color as my right one, basically the right one looks like an HID and the left one looks like a wannabe.
Old Nov 21, 2006 | 11:02 AM
CLS 6MT Navi
After work yesterday I drove the car, no problems or issues. This morning it was kinda cold (for Texas) in the low 40s, started right up in the carport, no problems. No buzzing, lights work fine. Another mechanic I know at the dealer who didn't look at my car told me fuse #7 goes out occassionally. Not sure which fuse they replaced.
I guess I can call dealer back and ask if they checked the battery out. Other dealer replaced stock battery at like 25k miles about a year ago, could be longer, with an Interstate I think it is. Pretty sad if you can't even get 2 years out of a battery, I know the stock batteries are crap. Mechanic friend told me they have to replace a lot of stock batteries anytime there is a cold snap or a hot snap.
----Sure I'm up for a photoshoot!
Old Nov 21, 2006 | 12:25 PM
All Mine's Avatar
I'm a Vagiterian.
I think my battery is starting to go bad, too. Had to start now.
Old Nov 21, 2006 | 05:36 PM
artbran's Avatar
666 Speed
I was about to make a new thread about this then found this one. My Pass headlight sometimes will not turn on when i attempt to turn them on. I'll turn them off and try again and same thing. If i open the hood and unhooked the wiring to the ballast, and then plugged it back in it lights up. Any ideas??? Maybe its the same thing. A bad fuse?
Old Nov 22, 2006 | 12:53 AM
Corrosion's Avatar
White as night.
I just put a new fuse from the spare fuse compartment and it blew out right away.
Suggestions?
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
