Headlight Advice
Old Feb 23, 2009 | 02:55 PM
tnobori1's Avatar
Missing my
Headlight Advice
I've been having lighting problems for months now and I don't know what else I can do. First, one of my headlights went out about a month before my other one failed. I bought bulbs (before checking the ballasts - I know, DUMB) and found out it wasn't the problem.
I bought 2 used ballasts and both lights would come on, then they would turn off after about 15 seconds. If I switched the lights off and on again, they would come back on and stay on. After a few weeks, the passenger side light stopped coming on, but the driver light stayed on after being switched off and on again. I figured it was another bad ballast...
Today, I turned them on and now the passenger light came on, but the driver side light won't. WTF???!!! I still have to turn the lights on, wait for them to turn off and then flip the switch off and on to stay on.
I'm at a total loss here... Is it a bad relay? Any other suggestions? I haven't done any mods that involve the electrical system. I even put in a new battery a month or two ago. Any help is appreciated!!
Old Feb 23, 2009 | 05:45 PM
combat mediC's Avatar
just to make it easier, i'd buy a cheap kit for 115 bucks or so, bulbs and ballast and completley rewire the monkey.
Old Feb 23, 2009 | 06:17 PM
tnobori1's Avatar
Missing my
I even did that, but didn't know how to wire the Phillips ballasts to the lamps... I posted in a thread asking for a wiring diagram or DIY and didn't get any response.
Old Feb 23, 2009 | 06:20 PM
maybe u could cut the oem and splice it to the new setup?
Old Feb 23, 2009 | 09:53 PM
tnobori1's Avatar
Missing my
It makes sense in theory, but I think it's a 5 wire (old) to a 3 wire (new) setup. I don't know what goes where, so that's why I made the post about the wiring diagram. If I had that, I could knock it out in an hour or two.
Old Feb 23, 2009 | 10:18 PM
fuzzy02CLS's Avatar
Check your HID fuses. They have been known to blow when a ballast goes. Also check all your grounds.
Old Feb 24, 2009 | 12:07 PM
tnobori1's Avatar
Missing my
I checked the fuses already... dumb question, but where are all the grounds?
Old Feb 27, 2009 | 06:46 PM
tnobori1's Avatar
Missing my
Update: I got in my car this morning. It was freezing out (for CA, anyway) at 36 degrees and neither headlight would stay on until I clicked 'em on and off for about 2 minutes. When one finally came on and stayed on, it worked the rest of the trip. I parked for about 15 minutes and when I turned them back on I had to play with the switch again and only the other light came on. WTF is going on? Really! I need some help, can someone shed some light on this?
Fuzzy, where are the grounds I need to check?
Old Feb 27, 2009 | 08:12 PM
MrFluffy's Avatar
To many cars in my garage
U need new Ballast for sure if you order the new after market ones u just have to splice them in if u dont know how you can send me a pic and ill explain it if you want ?
Old Feb 28, 2009 | 04:20 PM
tnobori1's Avatar
Missing my
You're awesome man! I'll email you in a few days!
Old Feb 28, 2009 | 08:45 PM
MrFluffy's Avatar
Try to send pic of stock wiring from as it may be difernt than mine and new ballast, also minor modification mayneed to be done where the bulb goes .
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
Mr.Tea
Oct 2, 2015 10:32 PM
