Header UPDATE
Old Apr 4, 2007 | 12:15 AM
  #81
jproy's Avatar
MP90 uninstalled
Just one. You need qty 2
Old Apr 4, 2007 | 08:11 AM
  #82
Oakroadsteve's Avatar
Roger that...Thanks for the help!
Old Apr 6, 2007 | 07:50 PM
  #83
Originally Posted by Teh Snaps
OK guys i found out the problem and everyone that said it has a whooshing header sound that all headers have was absolutely WRONG! The Gasket that came with the headers that went between the CAT and the header FAWKED up! So the whooshing sound was defintely a LEAK!!!!!!!!!!!!!!!!!!!!!!!!!
So know my question is where do i get this gasket from! Its a metal ring gasket! Of course it was sunday when i was doing this project and the acura dealership was closed. So i went to autozone, advance autoparts, oreilly's etc... The only thing I could find was a gasket for a V6 accord it was not big enough and would not work! Is this gasket going to be the same size the dealership will have or do I have to get this gasket from XS_POWER! I havent tried contacting XS but I already have a feeling it will be a BITCH!
I just had the XS Headers put in today. There is a definite hissing noise when you step on the gas. Teh did you ever get the gasket you were looking for? It would appear that I need the same fix.
I noticed zero seat of the pants improvement in acceleration. I am hoping that the computer has to adjust. I believe that disconnecting the battery lead for 1/2 an hour or so may speed up the learning curve.
I am going to take the CL out tomorrow morning and expect to beat my best 30 to 80 time of 7.3.
By the way my mechanic indicated that the quality of the XS Headers was excellent.
Old Apr 26, 2007 | 05:26 PM
  #84
LIPPSTUH's Avatar
Unregistered user
i'm a little confused, a read it over twice.
teh snaps is having problems with all the xs gaskets: 2 are for the headers and 3 are for the other part (i think someone said they're called compression gaskets).
so you can't use OEM because it's not large enough? i believe a few people said it's okay?
IF you can't use oem or xs, what do you use?
teh snaps: any updates?
Old Apr 26, 2007 | 06:37 PM
  #85
LIPPSTUH's Avatar
Unregistered user
i contacted nate @ comptech and he told me that the gaskets they use are OEM for the header part, but the compression gaskets are from a 91 NSX
Old Apr 26, 2007 | 06:45 PM
  #86
GreenMonster's Avatar
Generic gaskets from the local muffler shop... Like hemhaw and others have suggested...
Old May 2, 2007 | 02:23 PM
  #87
Kulrevon's Avatar
This is a 91 nsx
I am guessing its #9 (18212-SA0-003) but it could also be #14 (18393-SH3-S00)
Also has anyone tried heat wrapping them. Or if we get the gaskets it doesn't make a woooshing sound.
Old May 23, 2007 | 12:18 PM
  #88
J32A26MT's Avatar
I'll put you in the wall
Anyone confirm which NSX gaskets to use? What is needed for these Headers not to leak? 2 for after the A pipes and 1 after the B pipe? can we use the ones from the NSX? Also, i like the idea of heat wrapping them, i was going to do the same thing when i get mine. anyone tried that? Do you need new manifold gaskets as well? my car only has 23,000 miles on it i was assuming mine would be ok.
Old May 23, 2007 | 12:34 PM
  #89
Kulrevon's Avatar
can someone get what size the collector pipe is. Like if I needed to replace the flex pipe. what size flex pipe would I need?
Jul 16, 2017 07:33 AM
agupta3224
May 23, 2017 08:30 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
thegipper
Sep 28, 2015 01:01 PM
