Have to replace supercharge belt every few thousand miles
I have a Comptech Supercharge. I have to replace the supercharged belts every few thousand miles?
My supercharge pulley seems to have different grooves than the alternator side pulley
. The supercharge pulley is cutting up my belt!
Does anyone have the same problem?
6K on supercharge. First belt I didn't know it was slipping so it when for about 4K miles. I then installed a boost gauge then I notice my 2nd belt was slipping at about 2K miles. I wasn't getting full boost as quick, especially right after gear shift. The 3rd belt 10 miles, I think I over tighten this one
Hrmm, nope, I have about 8k miles on this belt with no sign of wear. I am sure Eric, who has more miles on his blower than Comptech, has the original belt.
Is it jumping teeth at all?? My kit was shipped without a spacer behind the SC pulley. This caused a misalignment issue which forced the belt to ride up the grooves. This added load to the tighten belt which caused a premature failure of the tensioner pulley. It disintegrated on a trip back from Columbus, GA loosing the belt too somewhere on I-85.
Everything was replaced under warranty except I made my own spacer washer to fix the problem.
Originally posted by fuzzy02CLS
Wow I had no idea you have to change the belt like that. Why? How much is a belt?
Re: Have to replace supercharge belt every few thousand miles
dude...check the alignment of the pulleys vertically. When we installed one on a 99TL at work...we had to check the alignment and tension like 6 times in a row to make sure it was perfect. After setting it run it and watch the belt as u rev the engine...it should'nt be moving from side to side at all. Either that or something else is completely wrong.
Re: Re: Have to replace supercharge belt every few thousand miles
Originally posted by scalbert
You have more problems than any other vehicle. First knock, then a blown engine and now you are going through belts like crazy.....
Check to see if there is a spacer, like a washer, at the back of the SC pulley.
Re: Re: Re: Have to replace supercharge belt every few thousand miles
my boost gauge shows that it is only boosting 3-4psi. I was boosting 6.5psi with the old pulley!
It seem that I am the only one that have pulley problem. I got my supercharge months before it was sold to the public. I told them about the problem but they said theirs was fine. I guess they fixed the problem without telling me. It is not an alignment problem. I will take a picture and post it on this website. Like they say a picture is worth a thousand words. Can you guys with supercharge check your belt to see if the two outside grooves are wearing more than the two inner grooves? Thanks
http://www.southfloridapulleyhq.com/
mada51589
Jan 9, 2025 04:40 PM
Phambam12
Sep 5, 2015 04:10 PM
asahrts
Sep 4, 2015 05:55 PM
