Got blown pistons??? (pics)
Old Sep 9, 2005 | 04:09 PM
rtatsutani's Avatar
Never had a clean run
Shop finally opened my block. Here's the #2 piston that had no compression.
Old Sep 9, 2005 | 04:13 PM
ghost_masterCL's Avatar
blech... I thought J32's had forged internals (or so I read in another post here), I guess somethign was seriously wrong there, or the forged internals are a lie.
do the other cylendar s have white scaring like that?
Old Sep 9, 2005 | 04:15 PM
anothercls's Avatar
https://acurazine.com/forums/showthread.php?t=173412
Old Sep 9, 2005 | 04:18 PM
02AV6's Avatar
563hp daily
Doesn't look good. With that much "juice" and improper AFR, I'm not suprised. Good luck with 3.5 swap!
Old Sep 9, 2005 | 04:23 PM
Lord Helmet's Avatar
I'm here in spirit...
Daaaaayummmmm! That's why I stay away from Nitrous!
Old Sep 9, 2005 | 04:28 PM
rtatsutani's Avatar
No, I doubt it, I think this one was a direct cause of the blown piston. I'm changing all the sleeves out for stronger ones so it's a non issue.
Old Sep 9, 2005 | 04:40 PM
rtatsutani's Avatar
Well, don't give nitrous a bad wrap on my isolated cases behalf. I still may have had an improper jet in there which would've have made it my mistake and not the nitrous setup. As far as I know, NOS on all my other cars (toyota camry 4 banger (55 shot dry), ford fairmont v8 (150 wet), civic (55 dry) have never had a problem except for burning out plugs quickly.
Honestly I think NOS is the best HP for the buck. Just as long as it is installed properly and all necessary precautions are taken. In my case, I think that using an unmarked jet from a friend who CLAIMS it was a 75 shot was the biggest X factor and stupid mistake in my failure .
Old Sep 9, 2005 | 05:05 PM
blk2001tlon19s's Avatar
318whp/289wtq @ 6psi
It has nothing to do with having nitrous. That could happen with supercharger or turbo if it doesn't have the correct a/f ratio. Nitrous itself won't do it but incorrect a/f will mess it up. I had nitrous on my car for over a year and used at least 10 bottles w/ no tranny problems and/or engine problems on my TL.
Old Sep 9, 2005 | 05:18 PM
mclarenf3387's Avatar
Just look at Mattg's old set-up and how much power he was putting down. Although I believe he went through a tranny, but so did plenty of non-boosted members.
Old Sep 9, 2005 | 05:24 PM
civicking's Avatar
i said this in your other post a while ago" i can't believe you didn't put a hole through the pistons with it running so lean, yeah do the compression test and also do a leak down test please. i would think you would have at least destroyed the pistons rings, does the oil smell like gas, if you they might be bad because with them holding no compression the fuel is washing down the cylinder walls into the oil. i mean you melted the ground electrodes, that is something to be proud of i have not seen to many cars do that. i would try taking to a place that has a small cameras that you can use to inspect the cylinders, it a really small camera and it goes in through the spark plug holes and you can inspect the piston tops, the cylinder walls and if the have one that moves you can inspect the cylinder head too, that is if it gets to that point of needed to do that."
i think i was right, as you can see it happened on the exhaust side, that means there was a ton of heat on that side, looks like that's where it found the weakest part of the piston, also maybe on the of the spark plug prongs was resting right there and got so hot that it created the detonation(spark knock) in the piston. also check out the white specs, that looks like its parts of the spark plug.
Old Sep 9, 2005 | 05:25 PM
erishe69's Avatar
Mmmmm Toasty
Old Sep 9, 2005 | 06:13 PM
rtatsutani's Avatar
You hit the nail on the head.
Old Sep 9, 2005 | 07:04 PM
mrsteve's Avatar
Looks familiar
Old Sep 9, 2005 | 07:50 PM
All Mine's Avatar
I'm a Vagiterian.
It does?
Old Sep 9, 2005 | 08:19 PM
mrsteve's Avatar
Originally Posted by All Mine
It does?
Yep... not my car though. And the one I saw looked like that x3
Old Sep 9, 2005 | 08:26 PM
All Mine's Avatar
I'm a Vagiterian.
Was it a CL?
Old Sep 9, 2005 | 09:02 PM
CleanCL's Avatar
my old car.. you couldnt see the piston heads because the cylinders were filled with coolant =]
Old Sep 9, 2005 | 09:03 PM
allmotor_2000's Avatar
That's detonation.... scuffing on one side means combustion occured while the piston was still on its way up - it moves to the side - looks like the 'burn' in the j32A2 puts more force on the exhaust-side - maybe shaping the piston better will help?!?
BTW, I have a spare piston, you want it??
Old Sep 9, 2005 | 09:05 PM
mrsteve's Avatar
Was it a CL?
Yes, supercharged CL-S
Old Sep 9, 2005 | 09:15 PM
o1s's Avatar
o1s
i burned some ground electrodes on plugs in my nitrous s14. but that engine was indestructable. mm 3.5. i want one too.
Old Sep 9, 2005 | 11:28 PM
scalbert's Avatar
Yep, as suspected. But atleast you are on your way to a better engine.
Old Sep 10, 2005 | 06:31 AM
rtatsutani's Avatar
Nope, but thanks for the offer. Going with the 3.5L upgrade.
Old Sep 10, 2005 | 07:48 AM
mrsteve's Avatar
Which pistons are you going to use with the 3.5?
Old Sep 10, 2005 | 07:52 AM
mrsteve's Avatar
Meh... Matt also had a lot of success with the UniChip... this guy wasn't using any type of tuning device (I believe).
I think Matt is still trying to sell the UniChip... might want to check on that.
Old Sep 10, 2005 | 11:10 AM
derelict's Avatar
Old Sep 10, 2005 | 01:22 PM
rtatsutani's Avatar
Going with the 05 RL pistons. Takin a chance with the high compression, but I should be alright. If I do decide to put NOS back in, I will use a MARKED jet! haha
Old Sep 10, 2005 | 02:16 PM
mrsteve's Avatar
Were you using any type of tuning or did you just throw the nitrous jet in there and call it a day?
Old Sep 10, 2005 | 02:58 PM
rtatsutani's Avatar
The Zex kit includes some kind of pressure inhibitor which I think is powered by the pressure of the nitrous which increases fuel pressure by means of integration into the stock FP regulator. I've seen my pressure increase to over 15 psi compared to stock max.
40@idle, 50@max and 65 w/Zex activated w/full bottle.
I have my doubts that it is enough but it supposedly is a good enough increase to handle a 75 shot jet.
But like I said, the unmarked jet could have been a 150 (or more???) for all I know which would definitely have caused major damage after running 1 complete bottle and 1 run of the full pressure of the newly filled bottle.
If I do decide to add NOS again, I will definitely get something to custom tune my engine since I will probably need it anyway with the 3.5 upgrade. What do you think? Think it'll run fine n/a w/o custom tuning? I don't have the money now for an emanage now, but if it'll help out a lot, I'll save up for it in the future.
Old Sep 10, 2005 | 08:35 PM
typeR's Avatar
go with the S2000 injectors so you have enough injector for a 100 shot
Old Sep 10, 2005 | 09:00 PM
NiteQwill's Avatar
Adventurist.
They fit very easily too....
Old Sep 10, 2005 | 09:02 PM
rtatsutani's Avatar
Yeah, I think I'm getting those injectors, CT FPR and CT inline fuel pump anyways. that'll be my next project when I get my car back.
Old Sep 10, 2005 | 09:41 PM
bigguyonbike's Avatar
13.2 @ 104.76mph
i have 2 s2k injector for sale in blackmarket if your interested.
https://acurazine.com/forums/showthr...51#post4373951
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SidhuSaaB
May 30, 2020 12:40 AM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
