Gear Shift selector backlighting
Old Jun 24, 2008 | 11:48 AM
Forwardmotion's Avatar
Last night, I noticed that the backlighting on the center console gear shift selector is out. My first question is how do I change it? Second question, is the bulb a dealer item or can I buy it aftermarket? As always, thanks in advance!
Old Jun 24, 2008 | 11:54 AM
evan03CL's Avatar
Wait...I just blacked out
I've always wanted to put LEDs under there, so hopefully someone can help us out!
Old Jun 24, 2008 | 01:57 PM
Corrosion's Avatar
White as night.
it's a tiny little bulb. If I remember correctly, Type 74.
Your best bet? Just remove all the trimming around the shifter and get to the bulb. Shouldn't take you longer than 5 minutes. (unscrewing the shift knob is NOT required to get to the bulb)
Old Jun 24, 2008 | 06:10 PM
RYANGP's Avatar
Not a doctor
the man speaks the truth
and i've got an LED in there
Old Jun 24, 2008 | 06:13 PM
aznboi2424's Avatar
Take the black/grey trimming off, the one with the hole for the shift lock override. It should pry up. Then take the grey/silver trim off and go from there. It should be pretty common sense now.
Old Jun 24, 2008 | 11:11 PM
Thanks again...I'm going to order the bulb from the dealer and put it in this week.
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
mellsonnj
Sep 24, 2015 04:42 PM
