Gas door problem
Old 03-23-2006 | 11:26 AM
Darkness's Avatar
3 the Hard Way
Angry Gas door problem
My gas door doesn't want to open anymore. I have to have someone holding the switch while I pop open the gas door with a paper clip. If you can visualize me doing this in a gas station, then you know it makes me feel like .
I took it to the shop and they said the lil metal clip on the inside of the door that latches gets bent sometimes. He bent it back and it was fine, but it started happening again.
Any ideas?
Old 03-23-2006 | 12:30 PM
fuzzy02CLS's Avatar
You can adjust the door by messing with the 2 bolts on the inside of the lid. Then bend the latch a little till it opens fine.
Old 03-23-2006 | 03:08 PM
Darkness's Avatar
3 the Hard Way
I think it's the latch that's the problem, not the hinges. What direction should I bending the latch?
Old 03-30-2006 | 01:25 PM
Darkness's Avatar
3 the Hard Way
hello out there...
Old 03-30-2006 | 01:45 PM
fuzzy02CLS's Avatar
Don't remember. Just try a small push in then try out. Don't go crazy. You can gently push it.
Old 03-30-2006 | 01:48 PM
Darkness's Avatar
3 the Hard Way
I tried bending it in several different ways but nothing seems to work. Has anyone else had this problem?
Old 03-30-2006 | 01:52 PM
rchavis's Avatar
Yeah, I just took it to the dealer and they fixed it. No problems since. That was 2 years ago.
Old 03-30-2006 | 01:55 PM
Darkness's Avatar
3 the Hard Way
how much did they charge you, if you remember?
Old 03-30-2006 | 02:08 PM
forrer13's Avatar
Any ideas?
Bend it back again......Keep it up until you win...
Old 04-01-2006 | 04:28 PM
Nitz's Avatar
I had a problem just like this on my Accord. I just wedged a cigarette lighter (the kind that comes in a car) under the switch to hold it open while I pulled the door open. Kinda ghetto but it worked
Old 04-02-2006 | 01:12 AM
CL'er 1st & 2nd Gen's's Avatar
Acura loyal for 93mo/109k
Maybe when you pull the release handle the pin (that locks into the latch hole) isn't getting pulled back far enough. You can adjust the cable tension. Just remove the covering over the release handle and you'll see the tensioning nut on the cable.
Old 04-02-2006 | 01:32 PM
fuzzy02CLS's Avatar
Yeah try that.
Next is to try to adjust the door from the hinge. There are 2 bolts. Loosen them slightly & you will be able to move the door in & out, left & right, & up & down.
Old 04-03-2006 | 02:20 PM
Darkness's Avatar
3 the Hard Way
That's what I've been doing. It ain't "kinda" ghetto: it's extremely ghetto! Slightly embarrassing even.
Old 04-03-2006 | 03:25 PM
fuzzy02CLS's Avatar
Come down to Boca & I'll fix it.
Old 04-04-2006 | 10:01 AM
Darkness's Avatar
3 the Hard Way
We might have to arrange that...I drive through Boca everyday to get to work...either that or I can have the stealership fix it for a couple thou
Old 05-04-2006 | 10:34 AM
Darkness's Avatar
3 the Hard Way
Never mind, I figured out.
MODS, you can close this thread, thanks
rockyboy
08-04-2024 11:35 AM
tman570
06-11-2019 08:56 AM
Azonics
09-22-2015 06:28 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 11:40 AM
ninersfgiantsfan
09-09-2015 02:14 PM
