Gap denso plugs before install?
Q. Do I need to set the gap?
A. Generally, no. The DENSO Iridium Power plug comes pre-set with a protective sleeve over the firing end, to protect the gap from accidental alteration. DENSO Iridium Power’s ultra-efficient firing power compensates for normally recommended gap settings that are smaller than the pre-set value. In the cases of vehicle modifications (nitrous, turbo-chargers, super-chargers, high power ignition systems, etc.), some adjustments may be desired. Or, if you prefer to remain consistent with factory specifications, you may adjust. However, please be careful not to place any stress on the fine center electrode during adjustment. You could accidentally break off the very hard, and therefore brittle, tip.
From FAQ
From FAQ
Stock NEW Spark plugs gap spec ( HELMS ):
1.0-1.1 mm (0.039"-0.043"), Service limit: 1.3mm (0.051").
Now the denso IK20 has factory gap: 1.1 mm (0.044")
IK20 Specs
IK20 Specs
IK20 Specs
IK20 Specs
Forgive me if i sound like a moron.
So according to those specs should we gap the plugs down to .039?
Always check and verify the gaps out of the box with a gauge! Who knows what could of happened at the factory or supplier. i.e. DROP!!
Originally posted by Scrib
OK, I'll bite...
What does it mean to 'gap' spark plugs?
Woo Hoo!!! I'm gonna learn something today!!!
OK, I'll bite...
Why?
Why?
Well if you look at a spark plug you have a gap between the tip and the electrode. "Gap" means to make sure the distance between the two pieces is what the manufacturer wants it.
Thanks Zapata!
So there must be a 'turny clicky thing' errr... a tool of sorts to check for this?
Thanks Zapata!
Thanks Zapata!
yah, my friend has a flat disc that increases in thickness. You slide the plug over and rotate the disk until it hits the metal then look at the corresponding number for the gap measurement. You should be able to pick one up at a autoparts store.
[QUOTE]Originally posted by Zapata
yah, my friend has a flat disc that increases in thickness. You slide the plug over and rotate the disk until it hits the metal then look at the corresponding number for the gap measurement. You should be able to pick one up at a autoparts store. [/QUOTE
educate me please.. whats the point in gettin denso iridiums.. do they actually provide any power gains?.. any noticeable differences to our N/A cars?..
cycdaniel
12-17-2019 11:58 AM
justin7779
12-25-2015 11:33 PM
