Fuse for the Check Engine Light?
Old Nov 18, 2004 | 02:24 PM
sundance_gold's Avatar
I'm taking my car to be evaluated for trade in and the check engine light is stuck on. Acura says it will go away eventually (reset itself) as everything has checked out with the electrical system.
Can someone tell me what fuse will get rid of that display?
Thanks!
Old Nov 18, 2004 | 02:26 PM
Chaptorial's Avatar
The CEL should go away after 3 cold starts.
Old Nov 18, 2004 | 02:29 PM
ok thanks!
OK just started it again...was off for 1 hour. I'll try it again at 4:30
Old Nov 18, 2004 | 02:40 PM
Chemmech's Avatar
Try disconnecting your battery, then push on your brake pedal a few times. Then re-connect the battery. This should reset all the codes, unless there's a problem.
Old Nov 18, 2004 | 03:05 PM
Chaptorial's Avatar
Also if all else fails just pull the No. 13 fuse.
To answer your first question.
Old Nov 18, 2004 | 03:08 PM
ah kewl thanks!
Old Nov 18, 2004 | 03:30 PM
unlucky 13
I pulled 13 and it made no difference (all lights still came on and all dinging etc).
Old Nov 18, 2004 | 03:33 PM
Chaptorial's Avatar
This was the No. 13 fuse on the passenger side fuse panel?
Pulling it out for 1 minute and plugging it back in should do.
Old Nov 18, 2004 | 03:34 PM
drivers side...I'll try the other one.
Old Nov 18, 2004 | 03:38 PM
That did it! Many,many thanks!!!
Old Nov 18, 2004 | 03:41 PM
Chaptorial's Avatar
Ah ok.
I should of said passenger side from the start.
Old Nov 18, 2004 | 05:53 PM
RaviNJCLs's Avatar
Man, that's good to know.
Old Nov 18, 2004 | 06:13 PM
Count Dracura's Avatar
Corpretty
Figures... lucky number 13
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
