Fuse for the Check Engine Light?
I'm taking my car to be evaluated for trade in and the check engine light is stuck on. Acura says it will go away eventually (reset itself) as everything has checked out with the electrical system.
Can someone tell me what fuse will get rid of that display?
Thanks!
Thanks!
Try disconnecting your battery, then push on your brake pedal a few times. Then re-connect the battery. This should reset all the codes, unless there's a problem.
HeloDown
09-08-2015 06:51 PM
