Front & Rear BBK / Ksport vs Rotora
So I've been doing some research on pricing and other crap. Basically I've come to pricing a complete BBK setup all around and looks like I can price an
8 piston front 6 piston rear 2 piece rotor 13" K-Sport setup under 3k.
A 2 piece rotor 13" Rotora setup with 4 pistons all around will run me well over 3k.
I'd assume the pistons in the K-Sport are smaller, but still, its considerably cheaper and may stop just as well if not better then the Rotora setup. Plus everyone is running Rotora's and their is a uniqueness to the orange calipers.
Anyone have any experience? I'd prefer hearing from vendors or those with a K-Sport BBK setup. If their coilovers are built as well as the brakes I will probably pull the trigger on them.
I don't know what kind of wheel clearance you would need either...
HOLY HELL i didnt know those ksports existed!
is the rotor coverage more than the rotora though?? 8 pistons could be garbage if it doesnt cover that much..
i beat the absolute hell out of my rotoras. they are fantastic once warmed up but, something a little bigger i would love. i do however still have stock suspension which creates massive nose dive, thus reducing my braking power
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Former Sponsor
It would be nice to have both front and rear BBK instead of the typical painted rear OEM calipers to match the fronts. I say go for it, just watch the clearance needed for the K-sports, running a spacer will most likely make you rub and/or lose the hubcentric feature of the wheels resulting in an annoying vibration at 60mph+.
i beat the absolute hell out of my rotoras. they are fantastic once warmed up but, something a little bigger i would love. i do however still have stock suspension which creates massive nose dive, thus reducing my braking power![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
The ksports look nice, but I havn't seen them pop up in this forum yet.
Whats up with RDX owners?
I remember seeing an M3 with the KSport BBK. Ive not heard much about them though.
^ Not really.
Look at this pic:
![](http://www.coolcarpartsonline.com/images/ksport/front_big_brake_kit.jpg)
The pistons are much smaller then that area.
Look at this pic:
Former Sponsor
I sell K Sport coilovers and they are a good bang for the buck: firm, track-inspired, damping adjustment, ride-height adjustment, etc. They are not on par with TEIN's quality but they work.
Personally, I wouldn't install a K Sport BBK on my vehicle. Bigger isn't always better and more pistons isn't either. This kit focuses on the bling and I'm fairly sure that if you tested it the brakes would lock up prematurely due to incorrect piston size and you would have longer braking distances.
The ROTORA BBKs' are more expensive but they do are a better design. Personally and professionally I think the STOPTECH BBK's are the best-engineered but you'd have to use a 3rd gen TL kit to fit on the 2nd gen. The brake lines are slightly different but everything else will fit; even the brake lines will fit but the fitting internal nipple is slightly different.
If you are going to get a rear BBK it will likely be a 2 pc disc so you will definitely want a 2 pc front disc BBK.
You can retain an e-brake, you just need to upgrade from the cable actuated handbrake to a hydraulic handbrake. It sends fluid into the rear brake calipers to lock them in place.
Lol. There seriously are products out there for it. It will require some work, but not much. Let me find one...
Aaaannnnnd.......
Got it.
http://www.amazon.com/Sport-HH0003-H.../dp/B000ZLNQGE
Aaaannnnnd.......
Got it.
there are a lot of forums that have the same views as you do... I agree that Stoptech BBK's are the best engineered. But, KSPORT locking up do to premature? not really. I had a Maxima prior to this with many people running them. They are lighter than our cars at 3120lbs. Still never locked up. Never had an issue.
If anything get a 6piston then...
lowrd on tein CS biatch
a few days ago I saw an 07 accord coupe tube chassis with an S2000 motor in it and is was DONE up... turbo, nos omfg everything! only making just over 800whp tho since the turbo is way to small they said lol.
I will try and get the vid from my buddy so I can show
Aaaannnnnd.......
Got it.
Aaaannnnnd.......
Got it.
rockyboy
08-04-2024 10:35 AM
09-04-2015 08:03 AM
