front grill
the grille does come apart, if you use the search function you should be able to find some more info on how and how many pieces it ends up being. I know i've taken mine apart, I'm pretty sure there's just some small screws on the back and around the edge that hold the pieces together. I can let you know for sure tonight though.
Yeah you need to get those black nuts off in order to remove the grill from the car & then you can access the screws that hold everything together. I suggest a pair of vise grips & turn them enough to loosen them. They should not be on tight, & once they are free you can turn them by hand. Dealer or dealer parts website is where you can get the replacement nuts.
White as night.
There are none for our cars, all those are custom.
I had the same problem when taking off my grill, just wiggle the whole grill around and it should come off from those 2 last screws.
Originally Posted by fuzzy02CLS
It's one of the original prototypes from Grilltech.
Originally Posted by brianlin87
spelling your own username correctly ownzz you bish.
make me one of your grills playa!
Hmmm.. ok, found some pics that are still up:
https://acurazine.com/forums/showthread.php?t=166584
edit: I still like the "mclarenf3387 grille" the best.... or is that one a Ronjon one...
double edit: Maybe it's the ccannizz11 I really like https://acurazine.com/forums/showthread.php?t=170391
TLDude876
12-28-2016 03:18 PM
