front grill
Old Mar 15, 2007 | 11:01 AM
teckademics gtr's Avatar
big bad bust
front grill
the black nuts on my front grill are all mostly stripped any way to take the chrome off or un strip the bolts thanks
Old Mar 15, 2007 | 11:11 AM
03silvertypeS's Avatar
the grille does come apart, if you use the search function you should be able to find some more info on how and how many pieces it ends up being. I know i've taken mine apart, I'm pretty sure there's just some small screws on the back and around the edge that hold the pieces together. I can let you know for sure tonight though.
Old Mar 15, 2007 | 11:15 AM
big bad bust
well yeah i see how it comes apart but its just the black plastin nuts on the back are all stripped
Old Mar 15, 2007 | 11:22 AM
aznxtallxboy's Avatar
tried pulling on the nuts with some pliers as you're unscrewing? maybe that'll work
Old Mar 15, 2007 | 11:23 AM
fuzzy02CLS's Avatar
Yeah you need to get those black nuts off in order to remove the grill from the car & then you can access the screws that hold everything together. I suggest a pair of vise grips & turn them enough to loosen them. They should not be on tight, & once they are free you can turn them by hand. Dealer or dealer parts website is where you can get the replacement nuts.
Old Mar 15, 2007 | 11:29 AM
big bad bust
yea i will try that but the last two that are on just spin they do not go any wear
Old Mar 15, 2007 | 12:16 PM
fuzzy02CLS's Avatar
The peg it screws into might be busted from the grill. It that case you will need a new grill.
Old Mar 15, 2007 | 12:39 PM
big bad bust
well wear can u get after market grill i like the look of yours fuzzy
Old Mar 15, 2007 | 02:10 PM
GreenMonster's Avatar
Nobody makes an after market grille... you have to make your own... lots of threads here if you search.
Corrosion's Avatar
White as night.
There are none for our cars, all those are custom.
I had the same problem when taking off my grill, just wiggle the whole grill around and it should come off from those 2 last screws.
Old Mar 15, 2007 | 02:14 PM
Fuzzy, is the the mcmaster material??
If so the original poster can search for McMaster or 9232T131 to find more grille thread...
Old Mar 15, 2007 | 02:20 PM
Titand19's Avatar
East Coast Boost.!
tiand19 grill ownzz you
Old Mar 15, 2007 | 02:34 PM
Corrosion's Avatar
White as night.
dirty as shit.
Old Mar 15, 2007 | 02:43 PM
fuzzy02CLS's Avatar
It's one of the original prototypes from Grilltech.
Old Mar 15, 2007 | 03:36 PM
I had forgotten about those guys... Set the wayback machine for 2003 !!
Old Mar 15, 2007 | 03:37 PM
brianlin87's Avatar
ASM I.S. Design FTW.
spelling your own username correctly ownzz you bish.
make me one of your grills playa!
Old Mar 15, 2007 | 05:15 PM
RonJon even told him to get 'em made at one time...
Hmmm.. ok, found some pics that are still up:
https://acurazine.com/forums/showthread.php?t=166584
edit: I still like the "mclarenf3387 grille" the best.... or is that one a Ronjon one...
double edit: Maybe it's the ccannizz11 I really like https://acurazine.com/forums/showthread.php?t=170391
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Sep 17, 2015 10:16 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
08 NBP TL
Sep 8, 2015 08:49 PM
