Folks w/ 18" Rims Please Respond
Also, tire, tire size, do you have springs (i.e. car lowered 1 1/2" or so, and if so and rubbing? Actually it would be nice if we could get a list generated in the garage area? A thought..
Eat Safe, Use Condiments
red CL-S, non-Nav
red CL-S, non-Nav
This is an excerpt from the post referenced above
"In response to your original question... the offset of the stock wheels is 55. I put on some 18" BBS RK's (and 225/40/18 tires) with 42 offset and there are no problems with rubbing. I've heard 235's will rub. "
-jb
-jb
my Rims offset is 43 and check the Pics and the size from the SIG.
Gold CL-S with comptech headers, mufflers,Springs, V-AFC,AEM CAI. ACE hyper black Wheels 235-40-18ZR.
In the future..Supercharger or turbo if there is any.
Gtech run 0 to 60 in 5.41sec
My car pics are On http://albums.photopoint.com/j/Album...521&a=11013539
everything you're looking for is in my sig.
and no, i do not rub..
the tires before these were Toyo proxes 245/40/18, which are wider.. and they didn't rub either.
careful though... my car is a CL-P... and from what i hear, wheel offsets differ for Premium and type-s
my stock offset is 45mm.
bottom line is getting any 18" rim is okay... even 19"...
the thing you gotta watch is your width. certain widths require certain offsets. i recommend not going any thicker than 18x8.
my wheels are too thick...trust me. i kno. steering wheel gets jerky sometimes too.
just go for 18x7.5" with 225/40 tires with a variable offset of 40-50mm. (for Type-S, the closer you get to 50mm, the better. for CL-Premium owners, the closer you get to 40mm, the better. Good luck people).
2001 CL Premium w/ Navigation (purchased 4/01/2000)
Satin Silver, Black interior
-Comptech sport springs
-18x8.5" Altstadt/Zivell Speed lightweight wheels
-225/40/ZR18 Pirelli P-7000 Supersport (front)
-225/40/ZR18 Pirelli P-Zero (rear)
-Raybrig road lamps
-Solaris 9005 hi-beams
-Raybrig road lamps
well my car will rub if i take it into sharp turns when iam alone.... and it will rub very easily if i have like three people in the car with me.
The largest tire I could use was 225/40/18 with a 42mm offset wheel. Anything bigger rubbed. AND I needed shaved rear fenders.
But if you can find a wheel with a higher offset (as the previous post suggested), you can throw a bigger tire on. That's your best bet.
Problem is, not as many wheels are made with high offset. It's fairly uncommon among cars (except Acura) to have a low offset. (meaning you need a high offset wheel to compensate)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
