Flush/Change Coolant ?
Old Feb 23, 2011 | 04:46 PM
ivan06106's Avatar
wazup guys i just found out today that i need a new coolant temperature sensor...but since i got it drain the coolant, so i could install the coolant sensor, i would rather just draing it an do a flush/change, but wanted to know were is the drain plug an what's the procedure of doing a flush/ change on an 03 acura cl s
Old Feb 23, 2011 | 09:34 PM
aznboi2424's Avatar
Drain radiator (peacock valve at the bottom)
Empty overflow bottle
Drain coolant from engine (under the car, look up. Hard to describe, hard to find unless someone points it out to you)
Fill overflow bottle
Fill radiator with honda blue coolant then run engine with heater on. Leave the radiator cap on until the fan cycles twice and add coolant as necessary.
cycdaniel
Dec 17, 2019 10:58 AM
merc009
Jan 27, 2016 10:34 AM
LeVeL
Oct 18, 2015 04:19 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
