fast passenger blinker/ signal...
Old Dec 30, 2009 | 07:58 PM
PAYMEE's Avatar
G.uns O.n D.emand
i tried to search and really didn't find much...i am thinking that the bulb is burnt out.... fuses seem okay..some quick a-zine help is appreciated
Old Dec 30, 2009 | 08:04 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
bulb is burnt out, just replace it, I think all cars do this
Old Dec 30, 2009 | 08:06 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
+1.
Old Dec 30, 2009 | 08:09 PM
Rajca's Avatar
wham bam thank you ma'am
easier to check the blinker fluid then to change teh bulb. just top it off
change teh bulb
Old Dec 30, 2009 | 08:51 PM
Nersh7's Avatar
blinker fluid???
Old Dec 30, 2009 | 08:55 PM
Rajca's Avatar
it was a joke
Old Dec 30, 2009 | 09:22 PM
Nersh7's Avatar
haha I was like wtf there's no such thing
Old Dec 31, 2009 | 10:58 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
hahahah blinker fluid!!! dude that was howls
but yea all cars do the fast turn signal thingy if a bulb is burnt out.
how else would one know if it's burnt out
Old Dec 31, 2009 | 11:09 AM
PAYMEE's Avatar
G.uns O.n D.emand
i figured that was the prob...just wanted to make sure...thanks guys
Old Dec 31, 2009 | 03:24 PM
friesm2000's Avatar
B A N N E D
not all car blink faster, but basically all modern ones do
some older cars will not blink at all, and just stay lite,
so a different pattern then normal more then likely means a bulb is out
or to check for burnt out bulbs, just turn on the blinkers and walk around the car to visually inspect them (hazards work too)
Old Dec 31, 2009 | 03:59 PM
MrFluffy's Avatar
To many cars in my garage
FYI If its not the right voltage It will blink fast as well mine blink fast because I replaced them with LEDs
My 1980 TA the light just stays on
Old Dec 31, 2009 | 04:09 PM
friesm2000's Avatar
B A N N E D
it is actually the increased resistence that makes it flash faster (aka: less amperage, which to it seems like an burnt out bulb)
and the TA is due to less amperage too, with not being able to heat up the coil (shit can't think of the proper name right now), and when the coil heats up it turns off, then when it cools off, it completes the circuit again, and the lights turn back on (and repeats it self for the blinking effect)
so an electronic vs a mechanical blinker unit
Old Dec 31, 2009 | 04:15 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Yep burnt bulb
Old Dec 31, 2009 | 04:55 PM
civicdrivr's Avatar
Turning the hazards on and walking around the car would have saved you some time
Old Dec 31, 2009 | 06:17 PM
Dan's Avatar
Dan
Confused
Sure about that?
Old Jan 2, 2010 | 10:46 AM
PAYMEE's Avatar
G.uns O.n D.emand
WOW YOU ARE SO SMART...WHY DIDN'T I THINK OF THAT I TRIED THAT AND THE HAZARDS WORKED... JUST THE PASSENGER SIDE BLINKER BY IT SELF WONT WORK... SEEMED WEIRD TO ME...PRETTY MUCH WHY I POSTED THIS IN THE 1ST PLACE
Old Jan 2, 2010 | 02:24 PM
civicdrivr's Avatar
Then why not turn the blinkers on?
Old Jan 2, 2010 | 04:18 PM
wait u mean the front passenger... or the whole passenger side?
maybe a relay for one side is fucked???
i dunno much about that shyt but it's a guess
i'm sure someone will set the record straight
Old Jan 2, 2010 | 06:19 PM
PAYMEE's Avatar
G.uns O.n D.emand
then why not turn the blinkers on?
huh..?? Did that and it didn't work...only hazards work..
Old Jan 2, 2010 | 06:57 PM
PAYMEE's Avatar
G.uns O.n D.emand
Originally Posted by cl-s progression 01
wait u mean the front passenger... Or the whole passenger side?
Maybe a relay for one side is fucked???
I dunno much about that shyt but it's a guess
ya one whole side isn't working...passenger side... Maybe it is a relay switch...where is it located??
Old Jan 2, 2010 | 08:17 PM
friesm2000's Avatar
B A N N E D
do you mean not working by it just being a fast blink???
Old Jan 3, 2010 | 09:38 AM
PAYMEE's Avatar
G.uns O.n D.emand
correct...when i try to use my passenger side signal i get a fast blink...both front and rear blinkers won't come on...however hazards on all 4 corners work properly
Old Jan 3, 2010 | 10:13 AM
my hypothesis is there is a separate relay for the hazards... and then a separate relay for each side of the car for the blinker system.
from the sounds of it, looks like a bad relay.
Did u change the bulbs on the car recently?? cause the resistance is what causes the relay to blink faster... so make sure ur bulbs are oem and are in good condition first.. then look at the relay(s).
i think they are located by the passenger firewall. but i may be wrong.
car electronics diagnosing is something II am not familiar with since I never seem to have electrical issues (amen).
but i think that's should be ur fix bro.
Old Jan 3, 2010 | 10:16 AM
Rajca's Avatar
theirs only one relay for the blinkers. when ppl put in led in their turn signals, some members change the relay so the blinkers blink slower, and they only change one relay bc their is only one relay to change.
Old Jan 3, 2010 | 10:20 AM
friesm2000's Avatar
B A N N E D
x2, yeah there should only be one relay to replace
also OP do you have navi??? cause hazard switch is in a different spot then the non-navi
Old Jan 3, 2010 | 10:38 AM
friesm2000's Avatar
B A N N E D
to OP looking at the wiring diagram, i think you might actually have high resistence in the turn signal switch, which is not allowing enough power through to light up the exterior bulbs, but is enough for the indicater light to light up
so you need a new turn signal stalk
Old Jan 3, 2010 | 11:39 AM
PAYMEE's Avatar
G.uns O.n D.emand
i actually had a little fender bender and recently got my bumper and driver side headlight fixed...since the accident my passenger side headlight(the prob light) has moisture in it and fast blinker prob
yes i have navi...
really...a new turn signal stalk..wtf would cause that to go...do you think the body shop fucked up my car's electrical when they replaced my driver headlight?
by the way...i am buying 03 headlights from bm and installing(because of the moisture) will this solve the prob or do i still need to fix the signal stalk?
Old Jan 3, 2010 | 11:45 AM
Rajca's Avatar
if its not the bulb, the connector from the car (part that plugs into the bulb) might be bad, causing a short or an open
Old Jan 3, 2010 | 11:54 AM
man I hate electrical diagnosis... on cars.
almost anything else is sooo much easier lol
Old Jan 3, 2010 | 12:11 PM
friesm2000's Avatar
B A N N E D
cause you are saying that the bulbs light up with the hazards, but not with the stalk, and it shares the same wiring from the fusebox/dashboard out to the lights
and to go bad, somebody might have hit it just enough, or pushed on it hard enough that it might have dislocated the pins on it
(i know on a 94 accord [not my old one]{runnings light were not working}, that they actually had a new stalk in stock, and that was only like 2-3 months ago, and the honda dealer carrys some parts, but not a whole lot
Old Jan 3, 2010 | 02:58 PM
aznboi2424's Avatar
if you need a stalk, check auto parts stores. I saw someone buy a turn stalk at pep boys.
Old Jan 3, 2010 | 03:00 PM
civicdrivr's Avatar
Get new bulbs first, see if that does anything. Its the cheapest thing.
Old Jan 3, 2010 | 04:31 PM
PAYMEE's Avatar
G.uns O.n D.emand
ya i'm definitely gonna check this out...thanks
so i have to buy an aftermarket turn signal stalk...wow...that blows..does honda/acura even stock them at their dealerships...how the hell do i replace it??
well i am hoping when i swap my headlights for 03's that the new bulbs are good to go...fingers crossed that it is only the bulb..
Old Jan 3, 2010 | 06:05 PM
friesm2000's Avatar
B A N N E D
ummm.... no they can normally order them for you if not in stock,
auto store will proably not have one for our cars, cause they do not go out all that often (normally they are broken instead), and when he saw someone walking out with one , it was proably for a older domestic (never know )
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
rhdune16
Sep 28, 2015 11:31 AM
Froid
Sep 27, 2015 06:16 PM
Brandle34
Sep 23, 2015 07:20 PM
STC
Sep 23, 2015 04:36 PM
