Excelerate Performance: INGALLS Engine Torque Damper Groupbuy!!!
#82
Whats up with RDX owners?
It appears that the bracket will not fit on with my Neuspeed bar. I need to cut off the last part of the bracket because that plus the strut bar = no threads to bolt onto. Thats OEM top hats BTW.
Thoughts on cutting the bracket and using three mounting holes?
#83
Just put mine on, couple of notes. One of the motor mount bolts felt like it was stripping on the way out and was very hard to turn. The new longer bolts that hold the bracket went right in however with no trouble. No need to support the engine from underneath. At the pass. side shock tower the end of the O.E. strut bar must be lifted up. I used a pry bar to do it, and I did loosen the two nuts under the small access door where the wipers are just in case. The plate they supply fits over the four studs, and I used a small hammer to coax it into place.
Otherwise was a easy job, will drive the car for impressions tomorrow.
#84
Drove around a good bit today and I like the damper. Firms up shifting into gear and upon acceleration. Worth it in my mind just to save our troublesome motor mounts. I'm glad I did it, took my about 45 minutes.
#85
Would you say it is worth it if you put down 240-250+ whp?
#89
![Stupid](https://acurazine.com/forums/images/smilies/imwithstupid.gif)
#90
2nd sign up list:
1) thelastaspec
2) kdawg8526
3) jaMezBOI
4) AznwayTL
5) JCharged
6) sbuswell
1) thelastaspec
2) kdawg8526
3) jaMezBOI
4) AznwayTL
5) JCharged
6) sbuswell
#94
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Can someone measure the distance between the holes in the top bracket for me?
#95
The holes where the dampener itself mounts? I plan on cutting my bracket sometime this week so if you dont have it by then Ill get them for you.
#97
(Mid-Atlantic)
(Mid-Atlantic)
No the holes where the bracket mounts to the top hat/strut brace, need the distance between them, a pic would help as well. I need to see if I can get them to line up with my 1G without having to drill new holes or fab a bracket
![Fluffy](https://acurazine.com/forums/images/smilies/fluffy.gif)
#98
Ok, I can take a pic of the bracket before I cut it. Im at work now but I can get a pic tonight.
#101
woo!!
yaa, order now:
I just did!!!
Call the XLR8 guy if you need stuff - heel help you out!
here's the link to the thread - were at ~11 now and that means they start to come!!!
https://acurazine.com/forums/showpos...4&postcount=82
You need the code: INGALLSGB
apply it in the check out
For updates keep ckecking the 2g tl thread here:
https://acurazine.com/forums/2g-tl-1999-2003-98/excelerate-performance-ingalls-engine-torque-damper-groupbuy-785413/
List now:
1) thelastaspec - Paid
2) kdawg8526
3) jaMezBOI
4) AznwayTL - Paid
5) JCharged
6) sbuswell
7) tweedle99 - (going to pay)
8) tweedle99 - (going to pay)
9) AMGala
10) Rajca
11) StreetKa
Let me know if you've paid and ill phone him with updates and get updates on shipping dates...
#103
2.947"
![](http://i23.photobucket.com/albums/b378/civicdrivr/IMG_20100811_005341.jpg)
3.791"
![](http://i23.photobucket.com/albums/b378/civicdrivr/IMG_20100811_005407.jpg)
.958"
![](http://i23.photobucket.com/albums/b378/civicdrivr/IMG_20100811_005316.jpg)
1.691"
![](http://i23.photobucket.com/albums/b378/civicdrivr/IMG_20100811_005144.jpg)
.983"
![](http://i23.photobucket.com/albums/b378/civicdrivr/IMG_20100811_005234.jpg)
1.695"
![](http://i23.photobucket.com/albums/b378/civicdrivr/IMG_20100811_005115.jpg)
3.006"
![](http://i23.photobucket.com/albums/b378/civicdrivr/IMG_20100811_005217.jpg)
3.780"
![](http://i23.photobucket.com/albums/b378/civicdrivr/IMG_20100811_005202.jpg)
1.659"
![](http://i23.photobucket.com/albums/b378/civicdrivr/IMG_20100811_005129.jpg)
Hope that helps. BTW, the crossed out section is where I need to cut.
I know it would probably help to see it on the car. And dont mind the dog hair on the carpet.
#104
(Mid-Atlantic)
(Mid-Atlantic)
Thanks Morgan
#105
Lead Footed
Just got mine. I'm right in the middle of some major maintenance work on the car, so I'll be doing that as part of everything else. Should be a few days as I'm doing new brakes, struts, bushings, ball joints, timing belt and axles, hub & bearing (don't ask why on the last 2
Ruf
Ruf
#106
#111
[QUOTE=helpwanted;12218296]and took twenty minutes to install:QUOTE]
How come you arent using the cowl pieces for the ct strut bar? I am working on installing mine. The bolts from my coils stick up alot more than stock. it looks like i will have to completely remove the strut bar to get the brackets on. Hopefully this goes somewhat smooth.
#112
B A N N E D
[quote=brian6speed;12259652]
or this is what i did personally, undo the strut top bolts, then jack up the car a little, so those studs drop down, then just slid the bracket underneth
How come you arent using the cowl pieces for the ct strut bar? I am working on installing mine. The bolts from my coils stick up alot more than stock. it looks like i will have to completely remove the strut bar to get the brackets on. Hopefully this goes somewhat smooth.![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
#113
[QUOTE=friesm2000;12259775]Yea that is what i was thinking, thnx for the tip. Going to Acura meet so no time to finish now tho.
#117
here's who has not paid...
2) kdawg8526 - Is going to pay<
3) jaMezBOI
4) AznwayTL - Paid
5) JCharged
6) sbuswell - Paid
7) tweedle99 - Paid
8) tweedle99 - Paid
9) AMGala - Paid
10) Rajca - Paid
11) StreetKa
12) DC3328 - Paid
13) ANC297 - Paid
14) Tom Blasing - Paid
15) LacViet - Paid
16) Assclown - Paid mutha fucka! __________________
17) SilverPhoenix - Paid
3) jaMezBOI
4) AznwayTL - Paid
5) JCharged
6) sbuswell - Paid
7) tweedle99 - Paid
8) tweedle99 - Paid
9) AMGala - Paid
10) Rajca - Paid
11) StreetKa
12) DC3328 - Paid
13) ANC297 - Paid
15) LacViet - Paid
#118
#119
UPS tracking numbers are starting to be emailed.
Delivery date will be ~Sept 8-9th
3) jaMezBOI
4) AznwayTL - Paid
5) JCharged
6) sbuswell - Paid
7) tweedle99 - Paid
8) tweedle99 - Paid
9) AMGala - Paid
10) Rajca - Paid
11) StreetKa
12) DC3328 - Paid
13) ANC297 - Paid
15) LacViet - Paid
18) xxxboboxxx - PAID!
3) jaMezBOI
4) AznwayTL - Paid
5) JCharged
6) sbuswell - Paid
7) tweedle99 - Paid
8) tweedle99 - Paid
9) AMGala - Paid
10) Rajca - Paid
11) StreetKa
12) DC3328 - Paid
13) ANC297 - Paid
15) LacViet - Paid
