Engine ticking noise
Old Dec 23, 2002 | 04:43 PM
Red Rocket's Avatar
I have found some earlier references to this issue, but have not seen real answers, or maybe I missed them. I have a 2003 6-speed with 6k miles. Recently I began to notice a ticking noise from the engine when the car was idling. I can give it a little gas, and the ticking stays constant - no change in RPMs (the ticking). I recently had the car serviced, and asked the dealer to check the noise. They claimed everything was in spec, and suggested the noise might be from fuel injectors.
Does this sound familiar or make sense? Anything I should be concerned about?
Old Dec 23, 2002 | 05:08 PM
TheModMole's Avatar
13 Second CLS Defender :)
50% chance its the injectors or 50% chance its the lifters (however they should change "tick" frequency at different rpms)
Old Dec 23, 2002 | 05:57 PM
allmotor_2000's Avatar
Ticking
If its NOT changing with RPM's.. its not the lifters nor the injectors. There is a solenoid that's bolted to the driver-side by the strut-asembly. This is an emissions thingy that ticks away every now and then... make sure its not that.
Old Dec 23, 2002 | 06:41 PM
russianDude's Avatar
How about ticking sound that apears under rear driver's side wheel? Its near muffler area... someone told me that its a fuel pump pumping gas, cause sound disapears when I press gas... but then it comes back up... ( I figured fuel can flow on its on sometimes ).
Its a constant ticking with the same frequency
Old Dec 23, 2002 | 07:08 PM
Ticking
The fuel-pump is in the back of the car (in the trunk). The only time you hear the fuel-pump is when you first turn the ignition to ON (without starting the car) and it turns on to pressurize the system and then shuts off. The ticking sound near the driver-side wheel is either the EVAP purse solenoid (which I mentioned earlier) or some other emissions-related solenoid. It's difficult to pinpoint every little sound because the more you start listening to them... the more different sounds you hear!!
Old Dec 23, 2002 | 07:25 PM
Re: Ticking
well, I have a ticking sound behind rear wheel ( driver's side ). It could be under the trunk, hard to tell...
The sound only begins when car idles for some time, I tired pressing accelerator pedal little bit, and ticking was gone... than in 30 seconds it came back.....
I thought the fuel pump is supposed to work when your car idles and that's the noise I am hearing??
I will show it to the dealer than, cause someone told me its my fuel pump pumping gas while car is idling....
Old Dec 23, 2002 | 10:02 PM
Jens H.'s Avatar
retired
It's the emissions control equipment as mentioned going about it's business.Nothing to worry about they are all normal noises.Jens
Old Dec 23, 2002 | 10:14 PM
So the ticking sound under the trunk or rear wheel is normal? Thanks! cause I was getting worried...
Old Dec 23, 2002 | 10:22 PM
cltypes6spd's Avatar
8th Gear
I have the same ticking noise, just started yesterday. 2003 cls 6 speed (1k miles). I found the cause of it. It's in the engine bay located between the brake fluid reservoir and the clutch reservoir. It's a vaccum solenoid that connects to the charcoal canister which is used for emmisions controls. Something about venting pressure. You can actually feal it pulsing when you touch it.
The noise is really anoying and can be heard fairly loudly from the inside of the car. I took it to the dealer and they said they would check it out. Run diagnostics on it.
Old Dec 23, 2002 | 10:44 PM
GOT PSI?'s Avatar
It's Go-Time.
I had a "ticking" noise from the engine as well. The dealership replaced my tensioner pulley.
Old Dec 24, 2002 | 02:28 AM
CL FWD SPEED's Avatar
What to do, what to think
I have the same problem too...but only sometimes though...only through acceleration then the clicking occurs....
Old Dec 24, 2002 | 02:51 AM
nate'sCLS's Avatar
I noticed the same when I got the car, rear wheel drivers side ticking.
Just figured it was normal.
Old Dec 24, 2002 | 08:26 AM
NOLACLS's Avatar
Yeah I have the ticking to...but mine changes with the RPM's (ticks faster when I rev the car) so this is normal right...this is the emissions thing?????
Old Dec 24, 2002 | 10:57 AM
Ticking
I do have another 'ticking' sound that does change with the RPMS... but its not the lifter or the valves or anything as I can only hear it when INSIDE the car... too much noise in the engine-bay to hear it with the hood open. I need to check all the belts. Unbelievable... 5K miles and all this shit!
Old Dec 24, 2002 | 11:00 PM
gsrblack's Avatar
Had dealer check mine out a week or two ago when I went in for my 1st oil change....told me the sound is normal and was coming from the vacuum solenoid....ticking can be heard inside the car, somewhere on the driver's side behind the driving wheel (in the hood somewhere)....told me not to worry about it...normal noise.
Old Dec 24, 2002 | 11:05 PM
It's the EVAP purse solenoid...
Old Dec 26, 2002 | 03:13 AM
Red Rider's Avatar
Subie Dubie
Re: Engine ticking noise
Bring the Red Rocket to a Sacramento or Bay area meet !! Check out our thread in Club meets. We need more 6 speeds
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
