engine noise in speakers?
Old Apr 6, 2005 | 03:12 AM
ianm1104's Avatar
anyone have engine noise in their speaker?
The engine noise started when i put in my in dash and i don't know how to get rid of it. Its a whining noise that whines with the rpms.
Anybody know how to get rid of this?
I got the wiring harness for the radio from crutchfield. Its the one that bypasses the stock bose amp. I heard from the rsx forum that everyone who uses that wiring harness has this same problem, Saying that you have to actually disconnect the amp and just use a 98 and up honda harness.
Someone know how to disconnect the bose amp and where its located?
please help!
Old Apr 6, 2005 | 03:26 AM
AcuraTL's Avatar
OG
It's called alternator whine that is caused by bad grounding. Either check your wirings to make sure the ground is proper or use a ground loop isolator and hope it will go away. If not, at least you can say that you have a turbo in your car.
Old Apr 6, 2005 | 06:42 AM
Shawn S's Avatar
This is a common problem with aftermarket A/V systems but not always the easiest thing to fix.
You should find more help over in the Audio/Video section of the Forum.
Please repost your question over there.
Sorry, but we are unable to move threads there right now.
Shawn S
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
