Engine humming
Engine humming
So I dropped in a k&n panel filter today and just wanted to clarify something. I expected more noise from the intake, but should the engine be humming now? Definitely wasn't doing that before I put the filter in. Its a low him, but noticeable. Any input is appreciated
Don't care...
I had the same issue recently when replacing the stock filter with a new one - very noticeable (and annoying) low hum. So its not necessarily the k&n. Make the sure the filter is oriented correctly and fully seated in the air box....or simply replace the whole mess with a CAI...
Make sure all your screws are tight, had the same problem before but found out the clamp and screws were not tight enough
Don't care...
^Yep. Everything seems to be together and tight but in fact it's not and leaking.
CL-S, the hum is most noticeable at idle when you're outside the vehicle. In my case, it was not subtle. It was bordering on Holy Crap, What's That territory.
I only removed the two screws closest to the drivers side fender, lifted it up, switched them out, and re-tightened the screws. It is very noticeable at idle, especially loud when you open the hood. Sounds like a vacuum, I just wanted to see if this was normal. I don't see how I could've possibly screwed it up just by doing the process I did. If it comes down to it, I may remove it and sell it, not a fan of the noise
lowrd on tein CS biatch
everyone's definition of a sound is different.. so the hum u think u have... some may hear ur car and tell u ur nuts.
but u are comparing it to before. so u gotta keep that in mind.
my guess is u are beating a dead horse...
did u crack anything? did u replace the screws properly? did u install it right side up? if yes.. stop doubting urself
SidhuSaaB
05-30-2020 12:40 AM
spoiler900
10-10-2015 06:48 PM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
