Effects of having an upperstrut bar and NO suspension mods when u push it
Old Apr 26, 2002 | 05:07 PM
Scooter's Avatar
'Cooter
and this was mounted tight as hell...
Old Apr 26, 2002 | 05:09 PM
Scooter's Avatar
'Cooter
stripped the paint right off
Old Apr 26, 2002 | 05:13 PM
HellaWhat's Avatar
*Hella* isn't a word.
I don't really see anythign wrong here.... That's what the bar was designed to do, stop the car from flexing. Just because there's paint doens't really mena much, it's doing it's job
Old Apr 26, 2002 | 05:17 PM
Scooter's Avatar
'Cooter
i never said anything was wrong...just the effects...nothing more...u draw your own conclusions (shitty paint, too much stress on the bar, etc.)
Old Apr 26, 2002 | 05:19 PM
HellaWhat's Avatar
hahaha!!! What u need is a strust bar the same color as the car so it don't show U know.... I've had one BIG beef regarding how their paint is layed on what... with a silver car, I beleive the underside is BLACK, with a Black car, the underside is SILVER!!! (Our bumpers are like this)
Old Apr 26, 2002 | 05:22 PM
Infamuz's Avatar
Retired Post Whore
Need some spray paint Scooter?
Old Apr 26, 2002 | 06:47 PM
edgalang's Avatar
Purchased: April 28, 2001
At least you know it's doing its job. If the body wasn't flexing to begin with you would have this "problem". I have the same thing.
Old Apr 26, 2002 | 06:56 PM
Shawn S's Avatar
Scooter,
I can’t believe you went through the trouble of removing that bar just to shave a few hundredths off your ¼ mile time.
Why not just pop some EX-LAX and take a POWER DUMP before the run ???
Shawn S
Old Apr 26, 2002 | 07:20 PM
mattg's Avatar
tell me he didn't really take that off to save weight.
Old Apr 26, 2002 | 07:57 PM
Shawn S's Avatar
YES.....This is from another thread:
im headin down...weather looks decent this time!!...im gonna b trying some alternative settings to try and dial in on the right combo...some of the settings include increasing pressure in the rears while letting air out of the fronts, taking off upperstrut bar, taking off BOTH road lamps instead of just 1, having much less gas in the car (1/4 or less), and debating on folding side mirrors in...this is in addition to the spare already being out.
tire pressure should make a noticeable difference
upperstrut bar is dead weight...every little bit counts, right??
road lamps is a debateable topic...could b a Catch-22
gas is dead weight also
side mirrors is a very debatable topic...i've heard many arguments for and against the idea...such as at these speeds, it won't make a difference, our mirrors, the '01's, are way too big and cause too much drag, etc.
so who can join me???? anyone film the races also???
Old Apr 26, 2002 | 08:14 PM
Fabvsix's Avatar
Cajun Gumbo Man
Hell......just go on a diet and loose 20 lbs. or so...........that will do it !
Old Apr 26, 2002 | 09:19 PM
Scooter's Avatar
'Cooter
Shawn S
how bout u practice what u preach big boy
o i got it...i'll just stop using Rogain so all that less hair weight will shave a tenth of a second
Old Apr 27, 2002 | 12:51 AM
AztecRol's Avatar
The Screeching Toyo's
Take a NARE bath before you go. You will be CLEAN AS A WHISTLE and at least 5 lbs lighter, 10 lbs if you are a hairy MOFO!!!!
Old Apr 27, 2002 | 01:38 AM
Austin519's Avatar
Shave the pubes man...or hell, cut off your D...the latter would save like 10-15 pounds in my case
Austin519
Old Apr 27, 2002 | 02:56 AM
NOVAwhiteTypeS's Avatar
okay this topic got hijacked by hairloss folks that are upsessed w/ nair
Old Apr 27, 2002 | 10:18 AM
BNut's Avatar
S/C'd Accord Coming Soon!
Check out the latest issue of SCC... they did a BUNCH of runs with three types of tires, street radials, drag radials and slicks.
The street radials were SLOWER when they ran them below 30 PSI. They were also SLOWER when they cooked them doing a burnout. Too cold and tires will be hard, too hot and they turn slimey. They used some type of laser thermometer to measure the heat of the tires before each launch and measured the PSI of the tires before each run as well.
Informative reading...
SidhuSaaB
May 30, 2020 12:40 AM
Aug 15, 2019 12:58 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Sep 21, 2015 08:44 AM
k6biv
Sep 10, 2015 06:37 PM
