edlerbrock throttle bodies
Old Jan 7, 2005 | 03:53 PM
typeR's Avatar
looks like we might have atleast one option...now what size? 70mm or 75?
http://edelbrock.com/automotive/
Victor Racing Throttle Bodies and Adapters for Honda/Acura
Based on our 5.0L Mustang throttle bodies, the Victor 70mm and 75mm race throttle bodies can be easily adapted to a wide variety of applications. We eliminated the idle air motor mount and all unnecessary vacuum tubes, making these throttle bodies especially well suited for boosted applications. The throttle arm has a cable wheel with multiple take-off points. They are cast and fully machined by Edelbrock, then assembled by Magneti Marelli and come complete and ready to run with a throttle position sensor installed and pre-set. These throttle bodies can be adapted to a number of applications using our 1/2" thick spacer/adapters. Intake port matching will be required.
70mm Throttle Body ....#3811*
75mm Throttle Body ....#3812*
70mm Spacer/Adapter for Honda and Acura ....#38112*
75mm Spacer/Adapter for Honda and Acura ....#38122*
70mm Universal Spacer/Adapter (undrilled) ....#38113*
75mm Universal Spacer/Adapter (undrilled) ....#38123*
Old Jan 7, 2005 | 03:55 PM
mattg's Avatar
i wonder how much $$
Old Jan 7, 2005 | 03:57 PM
typeR's Avatar
like 2 something
Old Jan 7, 2005 | 04:09 PM
typeR's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...945023729&rd=1
284
Old Jan 7, 2005 | 05:04 PM
Zapata's Avatar
Cost Drivers!!!!
why not the king motorsports machined one?
Old Jan 7, 2005 | 05:56 PM
scalbert's Avatar
There do not appear to be provisions for IAC, MAP and Cruise Control. In othere words, it is not worth it even if it fit.
Old Jan 11, 2005 | 04:25 AM
Sly Raskal's Avatar
Old Jan 11, 2005 | 08:41 AM
typeR's Avatar
the map sensor is on the TB? anyway yes it does away with the iac motor
Old Jan 11, 2005 | 11:31 AM
scalbert's Avatar
Yep, MAP is on the top of the TB. You will also lose cruise control...
Old Jan 11, 2005 | 11:33 AM
typeR's Avatar
never use cruise control...but what would happen with the map sensor? obviously we cant run w/o it
Old Jan 11, 2005 | 11:37 AM
1killercls's Avatar
GEEZER
estimated gains???
Old Jan 11, 2005 | 11:38 AM
scalbert's Avatar
It has to go somewhere; you would need to relocate it. And yes, it is required.
Old Jan 11, 2005 | 11:39 AM
scalbert's Avatar
Originally Posted by 1killercls
estimated gains???
3 - 5 WHP on a basic J32A2 6MT. I don't know if it would do much for a 5AT with the VSA throttle left intact (not an issue for typeR).
Old Jan 11, 2005 | 11:57 AM
typeR's Avatar
speaking ofwhich...get my pm on the resistors?
Old Jan 11, 2005 | 12:20 PM
scalbert's Avatar
I made a task reminder for myself to make it up in the morning.
Old Jan 11, 2005 | 03:56 PM
typeR's Avatar
schweet
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
