Ebay oversize Throttle body's
Old Jul 9, 2011 | 07:00 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
How dificult is it to adapt our map sensor on these throttle body's ? I am talking about the 80,90,100mm one's.
Also are the blox TB's a direct swap ?
The 76mm one looks tempting if it is a direct swap.
If not I might go for one of the monster TB's.
I talked to a machine shop and he said their would be no problem adapting what ever I wanted to my manifold so I thinking I should get something big.
Old Jul 9, 2011 | 09:21 PM
AARONSredTYPE-S's Avatar
I THINK THAT SOUNDS GOOD.
I WOULD STAY AROUND THE 80MM THOUGH.
I think maybe the others will be overkill...
I will be on here to see what your outcome is of this because i was wanting to do this as well later on............
Old Jul 9, 2011 | 10:07 PM
The inlet on the stock cls manifold is right around 65mm.
So It's going to take a bit of work to do 80mm or bigger.
If a stock 3.7 uses a 80mm TB I'm sure I could do a 90mm.
Since I'm wanting to do that boss hog Sh!t.
I'm thinking 90mm with 3.5" intake
or 100mm with a 4" intake
and get some plenum spacers made.
Any thoughts on either of these set ups ?
Old Jul 9, 2011 | 10:17 PM
JBlueCLS6's Avatar
I think it'll be a lot more difficult then you think. Doesn't Civicdrvr use an oversized TB that gave him several problems.
Old Jul 9, 2011 | 10:22 PM
I'm still thinking a 75-80mm will be plenty good..
As far as the fitment, i thought b-series engine throttle bodies worked with our cars? if so, then your golden
Old Jul 10, 2011 | 12:25 AM
civicdrivr's Avatar
The 80mm required the entire neck of the manifold to be rebuilt from scratch.
Old Jul 10, 2011 | 07:58 AM
brian6speed's Avatar
Lone Wolf
I wouldn't go bigger then 80mm.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
