E-manage boost sensor install...
You can turbo anything
I bought my e-manage used, so I wasn't sure if I am just missing the install page for the boost sensor. Either way, I am just wondering what to tap into for the boost sensor. Couldn't find anything on the actuall install.
So then is that what you did, because my setup will be very similar to yours...this will definitely save me some time.
my bad, it was vtec-v6 that posted it...here it is if you want to decipher which one it could be...other than IGP or IGPLS, I wouldn't come close to knowing which abbreviation it is...
http://www.v6performance.net/forums/...ad.php?t=19596
So you left your map sensor stock since you are running <10psi? You did not use the emanage boost sensor? What exactly did you do?
Look at those diagrams I supplied yesterday; pin 17. You will intercept the MAP sensor signal; this is required. It will also be the source for the E-Manage to read boost.
You will want to do exactly as we have already done in all steps.
