E-manage boost sensor install...
Old Feb 14, 2005 | 07:09 AM
speedr73's Avatar
You can turbo anything
I bought my e-manage used, so I wasn't sure if I am just missing the install page for the boost sensor. Either way, I am just wondering what to tap into for the boost sensor. Couldn't find anything on the actuall install.
Old Feb 14, 2005 | 10:22 AM
allmotor_2000's Avatar
If you are boosting < 10psi, use the factory MAP sensor. The yellow plug on the E-manage is for the boost sensor.
Old Feb 14, 2005 | 12:52 PM
speedr73's Avatar
So then is that what you did, because my setup will be very similar to yours...this will definitely save me some time.
Old Feb 14, 2005 | 01:13 PM
speedr73's Avatar
my bad, it was vtec-v6 that posted it...here it is if you want to decipher which one it could be...other than IGP or IGPLS, I wouldn't come close to knowing which abbreviation it is...
http://www.v6performance.net/forums/...ad.php?t=19596
Old Feb 14, 2005 | 01:48 PM
Hurleysurf24's Avatar
allmotor whats your aim?
i have some ideas that i want to roll by you and see waht you think
Old Feb 14, 2005 | 02:20 PM
speedr73's Avatar
I meant what should I tap into for the pressure...like what vacuum line?
Old Feb 14, 2005 | 03:40 PM
Nope, that's not what I did.
I don't have aim <-- what is that?
Old Feb 14, 2005 | 04:04 PM
speedr73's Avatar
So you left your map sensor stock since you are running <10psi? You did not use the emanage boost sensor? What exactly did you do?
Old Feb 15, 2005 | 10:43 AM
scalbert's Avatar
Look at those diagrams I supplied yesterday; pin 17. You will intercept the MAP sensor signal; this is required. It will also be the source for the E-Manage to read boost.
You will want to do exactly as we have already done in all steps.
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
