E-brake light problem
CL-Pride
Hi everyone,
This is not really a CL problem but for toyota sienna. But it has the same pedal emergency brake so i figure i can find some solution here.
I guess due to high usage of the emergency brake, the "brake" light will occasionally come on in the dash board even tho the emergency brake is off. I am guessing the wire is probably loose somewhere.
The light comes on when I did a hard brake and there is a g-force going forward or when I am making a right turn and a g-force going left. When I do the opposite aka turn left or accelerate hard, the light will go off.
Not Asian
Could be the same problem that the CL/TLs have. The master cylinder cap may have a faulty sensor. Just remove it and slide the float a little bit and make sure it moves freely. Another possibility is that there is a little filter at the bottom of the reservoir that might need replacing.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
brandnewcolony
09-12-2015 10:39 AM
HeloDown
09-08-2015 06:51 PM
