Does the headers increase the MPH at the top of 3rd?
Old Oct 7, 2002 | 10:24 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I noted that now flooring it in 3rd... I approacd 95 MPH and still hvae like 1000 rpms to go... So I guess now I can redline 3rd at 105+ MPH...
Anyone noted that? Does headers improve speed at the same rpm at the top of the 3rd?
Old Oct 7, 2002 | 10:27 PM
civic4982's Avatar
SHIFT_over.so.I.can.see
mph in third? I'm thinking that headers like any other performance part would only change how fast your engine finished 3rd ... MPH has to do with the ratio between engine/tranny/wheels... nothing to do with the hp of the engine... I'm thinking that at X RPMs in X gear that the car will always run at the same speed in MPH...
Old Oct 7, 2002 | 10:34 PM
Happy CL-S Pilot
I thoight the same, but I think I see 3-digit speed very quick now... so now I am only at the track I can note the difference.. I mean at the drag is the only place that I top 3rd at 7100rpms and shift to 4th!
Old Oct 7, 2002 | 10:39 PM
allmotor_2000's Avatar
Dunno... my 3rd tops out at 82 mph Oh yeah.. spd!
Old Oct 7, 2002 | 11:00 PM
SFLA_Type-S's Avatar
Sold 12/29/04 :-(
More HP does add more MPH. The general rule is you gain about 1 MPH for every 10-12 HP gained across the entire RPM band. If you are just peaking 10 HP at the end of your RPM band you will most likely not gain 1 MPH, however if you gain 10 HP over a more consistant range like (4500 to 6900 RPM) you will gain about 1 MPH.
Old Oct 7, 2002 | 11:01 PM
Add weight and wind-resistance to that formula... gets a tad more complicated!
Old Oct 7, 2002 | 11:03 PM
Rescuer's Avatar
Evil Bob Knieval
your 3rd tops out at 105??????
what!?
mine goes to 115 before i switch to 4th
and so does everybody else i know...
Old Oct 7, 2002 | 11:05 PM
Happy CL-S Pilot
If I remember Helms manual spec 103-113 for top of the 3rd...I guess the 18" would affect that...
Rescuer's Avatar
Evil Bob Knieval
1st 0 to 35-40ish mph
2nd 40-70 mph
3rd 70-115 mph
4th 115-150
5th 150
isn't yours the same thing?
Old Oct 7, 2002 | 11:09 PM
Happy CL-S Pilot
I think I was topping my 3rd around 105 on the drag... no way it was never close to 115!
Old Oct 7, 2002 | 11:11 PM
Rescuer's Avatar
Evil Bob Knieval
even when my car was stock i was still hitting over 110 in 3rd gear
maybe it's my atmosphere? :i have no clue:
Old Oct 7, 2002 | 11:28 PM
Maximized's Avatar
Re: Does the headers increase the MPH at the top of 3rd?
Nope....Your gearing hasnt changed so speed in gears is the same.
Old Oct 7, 2002 | 11:39 PM
spiroh's Avatar
Re: Re: Does the headers increase the MPH at the top of 3rd?
Max is on the money. With more HP you just get to the MPH faster. You still shift at the same MPH
Old Oct 7, 2002 | 11:51 PM
DeezNutz's Avatar
2ManyMiles
DeezNutz' 2 Cents for the Day...
/Start 2 Cents
I've definitely been over 110 in 3rd a few times (always under safe driving conditions of course), and agree with the fellows who say that HP does NOT increase the speed in a gear--it's all linked together the same, so you'll just get there faster.
/End 2 Cents
Old Oct 8, 2002 | 06:50 AM
Starter's Avatar
Have you changed the tires / rims while you were doing headers? A different size tire or rim will change your effective gear ratio and could account for some difference indicated on the speedo and tach.
Horsepower will never change your mph or rpms at any given point - that's controlled by the combined ratios of the tranny, differential and tire / rim combo..
Old Oct 8, 2002 | 09:20 AM
Happy CL-S Pilot
I have 235/40/18 Nittos 555 on Konig Imagine 18x7.7 +45
Old Oct 8, 2002 | 09:37 AM
Black CL-S 4-Life's Avatar
Floyd Mayweather Jr.
what!?
Old Oct 8, 2002 | 09:50 AM
TypeSKid's Avatar
Mine goes to 115 too.
If anyone has a Type S that doesn't do that, then it should be taken to the dealership, cuz something is definitely wrong.
Old Oct 8, 2002 | 09:55 AM
civic4982's Avatar
can you show any research that has matched this claim? MPH is purely based on diameter of wheel/tire, gearing, and RPM from what I know... I'd like to have correct information so correct me if I'm wrong...
Old Oct 8, 2002 | 01:25 PM
Kkranghkar's Avatar
Grammar Police
If you're talking about TOP SPEED, that's completely different.... but in 3rd gear, at 105 or 115 MPH or whatever, our car is nowhere near the top speed.... What's stopping us there is the rev limiter.
There is a direct connection between the engine crank, the transmission, and the wheels.... The only thing that affects car speed at the redline is: the engine RPM, the gear you're in, and the radius of your wheels/tires.
Old Oct 8, 2002 | 03:23 PM
Red Rider's Avatar
Subie Dubie
I've seen over 115 in 3rd several times. So i guess it would be of more help in 4th ?
Old Oct 8, 2002 | 03:24 PM
Rescuer's Avatar
Evil Bob Knieval
Originally posted by Black CL-S 4-Life
how am i stupid for what i said?
Old Oct 8, 2002 | 03:38 PM
TypeSKid's Avatar
LOL!
He always replies with that. I bet 1000some of his posts are that,
:P
Old Oct 8, 2002 | 03:45 PM
Relax man...I was agreeing with you.
Old Oct 8, 2002 | 03:48 PM
SiGGy's Avatar
Moderator Alumnus
Seems some people think adding HP gives you better top speed in each gear.
If you have two similar cars with the same wheels, transmission, tires, differential gearing and redline limit. Even if one has 1000hp and the other 260. Both will have the same max. speeds in each gear...
period. Modifying the engine doesn't change the gearing...
Now it could be possible the 260hp doesnt have enough power to max out the last gear because of wind resistance.
Old Oct 8, 2002 | 06:05 PM
Rescuer's Avatar
Evil Bob Knieval
use this smiley then
:P
Old Oct 8, 2002 | 06:24 PM
RAdams's Avatar
The things that affect top speed in a given gear are maximum RPM and effective gearing (gear ratio, final drive ratio and OD of the tire). Power has nothing to do with it.
Old Oct 8, 2002 | 06:28 PM
SilverBullet_RENAMED's Avatar
what!?
Same with mine.
IBankMouse
Jun 13, 2020 12:53 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
