Do you need alignment after spring install?
1 Post
After a spring install, I realize that the car needs to be re-aligned. But do I need to keep the back seat out of the car so they can alight the rear for caster/camber/toe? I wasn't sure if the rear gets aligned as well in this instance. Any help here?
The back seat should not need to be removed for alignment, also, wait a couple weeks for the springs to settle for the alignment. They will also confirm if you need a camber kit at this time.
Originally Posted by SickAcura
No you do not need to take ur backseat out at all, wht type of lowering spings did you get??
1 Post
The springs are about to be installed....I am putting on the H&R OE Sport springs. The reason I was asking about needing to get behind the back seat was that I didn't know that if you need to access any of the top bolts when aligning the car--or are the rear ones tightened into place during the install and you don't have to touch them after that.
cycdaniel
12-17-2019 10:58 AM
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
