Differences between 01, 02, 03
Old Sep 27, 2004 | 03:17 PM
Biohazard's Avatar
I wanted to know if there are any differences between 01, 02, 03 CL-S.
Old Sep 27, 2004 | 03:19 PM
BEETROOT's Avatar
Yeehaw
03 was available w/ 6 speed
03 tails have white strip instead of just a square for the reverse light
03 didn't come with road lamps
03 had different rims
not sure but I think 03 had body colored door handles too, and maybe different cup holder?
thats all I can think of...
Old Sep 27, 2004 | 03:20 PM
BEETROOT's Avatar
Yeehaw
Old Sep 27, 2004 | 03:22 PM
Biohazard's Avatar
so only POS automatic before '03
Old Sep 27, 2004 | 03:26 PM
BEETROOT's Avatar
Yeehaw
Old Sep 27, 2004 | 03:27 PM
Allout's Avatar
Blown is Best
Body colored Door handles and grill. Headlights are smoked instead of straight clear. 03 also had 6 spoke grey wheels instead of 5 spoke silver.
And yes - Auto only prior to 03.
Old Sep 27, 2004 | 03:41 PM
drewJ32A2's Avatar
drewLS6 soon
also the 03 had option of aluminum trim they have rolled tips on the tailpipes
Old Sep 27, 2004 | 03:42 PM
mrsteve's Avatar
Search!!!! This topic comes up every 3 weeks or so.
Oh and the '02 had different side mirrors than the '01
Old Sep 27, 2004 | 03:43 PM
Jonesi's Avatar
Side mirrors are different..
rbf351's Avatar
Registered User
also the mirror switch in the 01 didn't light up and the heated mirror indicator was red
at least that what i noticed when i got a 01 for a loaner
Jonesi's Avatar
I got owned by Steves Edit...
Old Sep 27, 2004 | 03:45 PM
mrsteve's Avatar
:jonesi: <-- you have no smile :jonesi:
Old Sep 27, 2004 | 03:46 PM
Allout's Avatar
Blown is Best
Do all CL's have only one temperature setting on the seats. My TL-P and old TL-S both had High and Low settings.
Old Sep 27, 2004 | 03:49 PM
mrsteve's Avatar
I have high and low in my '02 CLS
Old Sep 27, 2004 | 03:50 PM
UNCTYPE-S's Avatar
Above n Beyond
my 03 has high and low for both seats
Old Sep 27, 2004 | 04:15 PM
dgracer's Avatar
My 01 CL-S has hi and low. It is a rocker switch which isnt apparent. Hard to see the label.
Old Sep 27, 2004 | 04:33 PM
berny's Avatar
I need FI
Old Sep 27, 2004 | 04:34 PM
berny's Avatar
I need FI
Old Sep 27, 2004 | 04:38 PM
Dead-Fox's Avatar
LMAO!!
Old Sep 27, 2004 | 04:43 PM
riceboy's Avatar
Darth Tator
02 and 03 has thicker moonroof glass
Old Sep 27, 2004 | 05:23 PM
darrinb's Avatar
///M POWER
thicker exhuast tips on 03, emblom in the wheel, titanium trim
Old Sep 27, 2004 | 05:59 PM
rezurex's Avatar
drop em like its hot
01 is faster
Old Sep 27, 2004 | 06:03 PM
anothercls's Avatar
The 03's with the dual setting on the seats must be for the automatics, cause I only have one button.
Old Sep 27, 2004 | 07:10 PM
FunkeeTown's Avatar
friend of fast
03's come with less miles....?
Old Sep 27, 2004 | 07:24 PM
123456SPEED's Avatar
CLS 6MT Navi
2003 only
-Anthracite exterior color
-Floormats marked 3.2 CLS, not Acura
-Supposed to have thicker glass in all windows?
-One setting seat heaters on 6 speed at least
-Center console Handbrake on the 6 speed
-Auto up AND Down on driver window, might have been on other years??
-Onstar packaged with the Navigation system
2001 only
- Sundance Gold exterior Color
Old Sep 27, 2004 | 08:13 PM
niz181's Avatar
the 03's are BETTER
UNCTYPE-S's Avatar
Above n Beyond
03's=sexy!!!
Old Oct 3, 2004 | 02:09 AM
ccannizz11's Avatar
My Work is Done Here
Old Oct 3, 2004 | 08:42 PM
LaurenCLS03's Avatar
8th Gear
I also have a 03 6 speed and only one setting for the seats...wierd.
Old Oct 3, 2004 | 09:43 PM
clsnavi's Avatar
9th Gear
2003 Acura CL Press Release / Changes for 2003
2003 3.2 CL Luxury Performance Coupe
Summary of Changes
For the 2003 model year, Acura’s goals for the 3.2 CL were to:
• Increase performance
• Update styling for a sleeker, more aggressive look
In support of those goals, the 2003 3.2 CL has received the following enhancements:
Powertrain
• While it continues to come with a 5-speed Sequential SportShift automatic transmission, the CL Type-S now offers a new close ratio 6-speed manual transmission as well. Models with the new manual transmission also feature:
o Helical limited slip differential
o Curb weight of 3446 lbs. (compared to 3510 lbs. for the CL Type-S with automatic transmission)
o Multi-cone synchronizers
o Self-adjusting clutch with dual-mass flywheel
o Short-throw shift linkage
Chassis
• CL Type-S with manual transmission replaces the VSA found in the CL Type-S with automatic transmission with new helical limited slip differential
• New 6-spoke 16 inch wheels (3.2 CL)
• New 6-spoke 17 inch wheels (CL Type-S)
• CL Type-S with manual transmission adds two hydraulic engine mount dampers to counter engine movement
Body
• Front Styling
o Revised grille with body-colored surround
o Revised headlights with black accents
• Rear Styling
o Revised taillight lenses with clear upper portion
o New exhaust finishers
Safety/Convenience
• OnStar is standard equipment on CL models equipped with the Acura Satellite-Linked Navigation System
• Lower Anchors and Tethers for Children (LATCH) System added on outboard rear seats for child safety seat attachment
• Driver’s Dual Stage Supplemental Restraint System (SRS)
• Auto-up driver’s side window
Interior Styling
• CL Type-S
o Models with black interiors receive titanium-look trim on doors and center console
o In models with 6-speed manual transmission, center console redesigned to accommodate manual shifter and hand-operated parking brake
o Perforated leather door inserts
Old Oct 5, 2004 | 08:29 AM
rbf351's Avatar
Registered User
not true, i have an 03 6 speed and i have 2 settings
Old Oct 5, 2004 | 08:47 AM
Black CL-S 4-Life's Avatar
Floyd Mayweather Jr.
Originally Posted by rezurex
01 is faster
Old Oct 5, 2004 | 09:11 AM
stejus's Avatar
Manny Tranny
Where do you find the temp adjustment?
Old Oct 5, 2004 | 09:23 AM
GreenMonster's Avatar
Yeah, the 03 side mirrors are body color, while the other 2nd gens are black.
Check out the FAQ forum too...
Check out Page #4 of this pdf....
http://john-perry.com/acurazine/docu..._new_items.pdf
Old Oct 5, 2004 | 02:20 PM
Allout's Avatar
Blown is Best
Can you post a Picture? I'm curious how it looks.
Old Oct 5, 2004 | 02:28 PM
rbf351's Avatar
Registered User
here you go
Old Oct 5, 2004 | 02:32 PM
N.O.6speed's Avatar
WESTK
the dual settings everyone was referring to was the heater, high, and low. The 03 6speed only has one setting on/off.
Old Oct 5, 2004 | 02:52 PM
rbf351's Avatar
Registered User
ah i thought he meant the memory switch, yes the 6 speeds only have 1 setting for the heated seats, no idea why, but some reason acura decided we don't need high and low
Old Oct 5, 2004 | 06:47 PM
andyjl's Avatar
also some of the later model 03 CL doesn't have the extended 7yr/100k mile warranty cuz Acura supposedly has fixed the tranny problem that the 01,02, and the early 03 models were having.
Old Oct 5, 2004 | 06:54 PM
spdy0001's Avatar
I now drive an accord....
If you search you will find that the 03 6-spd's have one button but its auto switching from hi to lo to maintain a good temp. So actually its better
