Did i mess up when installing my CT springs?
Old 02-23-2003 | 10:25 AM
beerknurd's Avatar
Busy Living
It seems the driver side rear is lower then the pasenger side. Not by much though. I bought the springs used, so they shouldn't need much of a break in period. I've driven about 30 miles with the new springs. The person i bought them from labeled each of the springs, and I triple checked the correct spring was where it was assigned.
any suggestions?
Old 02-23-2003 | 12:39 PM
beerknurd's Avatar
Busy Living
Turns out it was cause one tire had 7lbs less air then the other.
but thanks for everyone's help.
Old 02-23-2003 | 12:40 PM
peiqinglong's Avatar
You need to swap sides perhaps. The driver side should be slightly higher. The reason for this is so when the driver is in the car, the drop appears to be even.
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
jblessing
08-08-2018 09:43 PM
SinCityTLX
63
03-23-2016 02:13 PM
HOWELLiNC
09-10-2015 01:39 PM
Quick Reply: Did i mess up when installing my CT springs?
