DEPRESSED!!! 221WHP with SUPERCHARGER!!!???!!!
#321
B A N N E D
Originally Posted by mrsteve
Please tell me the gauge isn't mounted inside the cabin.
38psi static? You should be adjusting your static fuel pressure. Not in vacuum.
fuel pressure is set while the car is running at idle. if ud like to elaborate whether that is static or in vacuum, your more than welcome
#327
You shouldnt even need to touch the fuel pressure/adjust the FPR if you're running the standard boost pulley from the SC kit. Everything should've been running fine out of the box.
#331
Some fine tuning may be required on each car. It's no uncommon.
#336
Don't Mess With Texas
Originally Posted by horsepowercrzy18
me and samir changed his spark plugs and wow what a difference. night and day. i believe that solved the problem!
#340
hey
the spark plugs he had in the car before we changed em were bad. they werent even working because of the electrode on the tip of the plugs being broken off. about 3 of the previous plugs were bad
#346
THE J35A2...
Originally Posted by L's TL
sincer we r on topic...how vital is it to have the IK22 for the supercharger compared to the normal irdium plugs?
Originally Posted by CleanCL
didn't he yank the plugs earlier in this thread? the OP should not be allowed to work on a car.
Originally Posted by New Image
Well, yes, the plugs were finally changed. It ran great. The next morning its misfiring again. Im changing the ECU tonite. fuckin eh
#347
4drs just wanna have fun!
Originally Posted by SIRSIG
not strong enough...
trade in the owner???
lol
dont easily jump on the ECU man, if you have tried to check the coils? what's the plugs look like? Clean the inside of those coils slot, check for water or moisture... try NGK's, that equievalent to IK22.
Well you just need cooler plugs the IK20s are just as strong as IK22s they're just a hotter heat range. You want to transmit less heat to the next intake charge with the IK22s
It seems as if the OP should just send the car to a professional shop to get his problems taken car of quickly and efficiently, instead of doing a random diagnostic over the span of a month or two, like some other people on this board
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#349
I see no reason to spend thousands of dollars on a supercharger kit and then skip the $70 spark plugs.
![Ghetto](https://acurazine.com/forums/images/smilies/ghetto.gif)
#350
If they weren't absolutely required they wouldn't be packaged with the kit.
#351
2600lb CL
Check to see if you skip a tooth on your timing belt.
Don't run your car during cold starts.
Check your o2 sensors.
Check to see if your timing marks on the cam gears are where they should be.
Hell, do you have 93 octane? Car seems to be in limp mode.
Did you do a leak down compression test? Pretty sure you did, but I'll ask anyways.
And lastly, I truely wish I remembered the name of the part, but all cars have a ______ that protects the ecu from "going out". So usually you would replace that part before ever thinking about changing the ecu. If only I could remember the name of that part for you to check out.
I really don't know what else to tell you. At this point, I would hand the car over to a great tuner shop, and tell them to do what it takes to fix the issue. But that's just me.
#354
B A N N E D
