DEPRESSED!!! 221WHP with SUPERCHARGER!!!???!!!
Old 09-11-2007, 08:05 PM
  #121
B A N N E D
New Image's Avatar
i just inspected my IM and it was filthy clogged. one of the runners was about 40% clogged. unbelievable. never seen that b4.
Old 09-11-2007, 08:23 PM
  #122
318whp/289wtq @ 6psi
blk2001tlon19s's Avatar
holy cow those are low #'s. Need to get that done quick. Those #'s are lower then my stock evo dyno #'s.
Old 09-11-2007, 08:29 PM
  #123
mrsteve's Avatar
They are lower than some stock CL-S 6-speed numbers I've seen.
  #124
mrsteve's Avatar
Originally Posted by New Image
oh yea, one other issue i had was that the car would stall at low speeds, or revving high and then letting it drop back down to idle, the rpms would drop too low and stall the engine.
i pray this fixed it
IAC valve adjustment or PVC/vacuum leak.
Old 09-11-2007, 08:30 PM
  #125
mrsteve's Avatar
Originally Posted by Accord_V6_400m
What you need to do is take you car to a place that can read ignition advance/retardation and see if timing is being pulled, because that will cause major power loss.
Or just purchase a scan tool for $150-200.
Old 09-11-2007, 08:32 PM
  #126
B A N N E D
New Image's Avatar
how can the intake air control valve be adjusted?
Old 09-11-2007, 08:33 PM
  #127
mrsteve's Avatar
You really just need to invest in the scan tool. See what the timing is and to see what the MAP is reading.
Old 09-11-2007, 08:41 PM
  #128
B A N N E D
New Image's Avatar
sounds like a plan. im putting her back together now
Old 09-11-2007, 08:59 PM
  #129
THE J35A2...
SIRSIG's Avatar
Originally Posted by SIRSIG
first off, you have to fixed the misfiring problem first before you install the SC
i think 2.93v is about right on your ESM, so i dont think it's your ESM. check your TPS and other sensor, see if they're plugged-in wrong. Coilpacks are known to go bad. you can check them by unplugging the connection while the engine is running. Adjusting the valves aren't hard but time consuming, just make sure do not over tighten it. I'm pretty sure you know some of what i'm talking about...
and put that gaddamn headers already!
Old 09-11-2007, 09:04 PM
  #130
THE J35A2...
SIRSIG's Avatar
dunno if this can help but...
http://www.artsautomotive.com/HondaV...Adjustment.htm.
Old 09-11-2007, 09:24 PM
  #131
B A N N E D
New Image's Avatar
thanx siggy. i actually saw that link earlier today.
im cleaning her up, and ready to fireher up very soon God willingly
Old 09-11-2007, 09:30 PM
  #132
B A N N E D
New Image's Avatar
im so anxious to fire her up. wish i could with everyting disassembled
Old 09-11-2007, 09:39 PM
  #133
Blown is Best
Allout's Avatar
How the hell do you continue to post so much while you're working on your car. Stay focused and get it done already
Old 09-11-2007, 10:13 PM
  #134
B A N N E D
New Image's Avatar
i get lazy and smoke a cig. covers r on. imrc on. IM time
Old 09-12-2007, 02:28 AM
  #135
4drs just wanna have fun!
Accord_V6_400m's Avatar
Do those scan tools actually give you that info? Guess im used to the cheaper ones, that or I just forgot the ones Autozone gives out can do that.
Old 09-12-2007, 03:01 AM
  #136
sinfulj32's Avatar
hey man clear your pm box. did you paint eyebrows on your headlights? i want to see pics of your car, it looks like its changed quite a bit
Old 09-12-2007, 03:11 AM
  #137
sinfulj32's Avatar
dude, you said it yourself. you have misfire on all cylinders. a valve adjust isnt going to fix a 6 cylinder misfire. at least im pretty sure it wont. my bet would be that some of your valves are bent. no way would you be getting full benefit of your SC with bent valves
Old 09-12-2007, 06:08 AM
  #138
mrsteve's Avatar
Yes! Some only show DTCs but many are designed to show a real time readout of many engine sensors.
Old 09-12-2007, 08:31 AM
  #139
CleanCL's Avatar
coil packs?
Old 09-12-2007, 08:40 AM
  #140
GreenMonster's Avatar
Can't we keep it all in this thread?
merging threads now...
Old 09-12-2007, 01:04 PM
  #141
B A N N E D
New Image's Avatar
Ok, well i finished last nite and started the car up. it was pretty smooth and quiet and then after it warmed up the valves are ticking very loud. I assume they went from being very tight fairly loose. I aint about to tear it apart again just to re-do it. The power issues are still there. Power surges after 5000 rpm, b4 that it feels like a slush box.
Do those scan tools read timing? and if so, would I know if my timing is correct?
Old 09-12-2007, 01:16 PM
  #142
CleanCL's Avatar
i'm assuming you adjusted the valves to factory spec?
still i would listen to the main man here, mr.steve, redo the solder on your ESM, replace your PCV (it's like $15), and clean/replace the IAC (i think its like $40)
Old 09-12-2007, 01:46 PM
  #143
B A N N E D
New Image's Avatar
yes i adjusted to factory spec but now they tick. i adjusted it on the conservative side being that they were so tight to begin with. lemme record it and upload a video on here.
Old 09-12-2007, 02:32 PM
  #144
B A N N E D
New Image's Avatar
Exclamation Video
motor tick
http://www.youtube.com/watch?v=1OS2fTzL24I
Old 09-12-2007, 03:20 PM
  #145
fuzzy02CLS's Avatar
That car is jacked! Uninstall everything & dump it. Start again.
Or take all mods off get it back to stock & then fix it right then add the mods back on. It's hard to troubleshoot your problems with the blower & mods on there. At this point it all guess work. You need a base to start with.
Old 09-12-2007, 03:29 PM
  #146
B A N N E D
New Image's Avatar
yea, I have this feeling the misshift caused all of these problems. the wierd thing is that I thought bent valves tick. but they werent. but now they do after I adjusted them to factory specs?
Old 09-12-2007, 04:02 PM
  #147
CleanCL's Avatar
i duno.. every J i ever heard ticked to some extent, but i haven't listened to your video yet.
Old 09-12-2007, 04:09 PM
  #148
Well...it's kinda fast...
2CLean's Avatar
Wow, that engine sounds fukk'd, definitely not normal J-series ticking. Wow, I'm so suprised...you seem to take such good care of your rides...good luck, man.
Old 09-12-2007, 05:01 PM
  #149
B A N N E D
New Image's Avatar
just took it to jotech motorsports. they said to readjust the valves. theyre too loose. so looks like im back to the drawing board.
ESM connections are fine.
Old 09-12-2007, 06:26 PM
  #150
Blown is Best
Allout's Avatar
Before you go through the effort of readjusting the valves, I would do a compression test and leakdown test to find out if you've got a motor to work with.
  #151
sinfulj32's Avatar
BENT VALVESSSSS
Old 09-12-2007, 06:47 PM
  #152
B A N N E D
New Image's Avatar
ive been doing research, and I find that misfire codes on all cylinders could be from a bad cat.?
if so, im going to kick my ass if thats the case. i suppose to disconnect the cat and see how it runs?
Old 09-12-2007, 06:48 PM
  #153
B A N N E D
New Image's Avatar
Originally Posted by sinfulj32
BENT VALVESSSSS
it wasnt ticking like that prior to the valve adjustment
Old 09-12-2007, 06:59 PM
  #154
sinfulj32's Avatar
misfire in cylinders is also caused by bent valves. they could just tick when they are adjusted to spec. i know a few people that have cl/tl that have bent there valves. reving to 9k is usually going to have some sort of bad results with your valves. bentvalves are my bet.
Old 09-12-2007, 07:31 PM
  #155
fuzzy02CLS's Avatar
You likely do have bent valves, but they are not causing your power problems. This is from experience cause I had bent valves in my 1st 6mt CLS. Wasn't me it was a demo car when I bought it & didn't know any better. Fixed under warranty with 1200 miles on it.
If bent valves were causing your problems they would need to be so bent normal driving before the blower would have giving you problems. Bent vales on the CL from my experience creates a erratic idle feel in the exhaust at idle. Almost like a stalling feeling. You'd be able to hear it in the exhaust from the rear as well. It would also make your valves tick a little more or less.(hence why your adjustment to specs created more tick) these are all problems you are having, but as I said the car would not be drivable or you WOULD notice it before the charger went on.
The other problem you mentioned about revving & then letting go of the gas the rpm's dropping & the car stalling shounds like a dirt or bad IAC sensor. I also had this problem. A new IAC valve fixed that.
Advice... re-adjust the valves, get a new IAC sensor, O2 sensor,(bad one causes misfires) & check your coil packs & spark plugs. Do a compression check on all cylinders, & then report back.
Old 09-12-2007, 07:47 PM
  #156
B A N N E D
New Image's Avatar
What about the catalytic converter? What to do with that? How can I check if it is the problem behind my misfires?
Old 09-12-2007, 08:15 PM
  #157
B A N N E D
New Image's Avatar
to clarify something
the feeler gauges i used were .008 / .203 for intake and .012 / .305 for exhaust
did i use the correct gap gauge? this whole conversion thing is confusing me
Old 09-12-2007, 08:32 PM
  #158
mrsteve's Avatar
Get a scan tool yet?
Old 09-12-2007, 08:35 PM
  #159
mrsteve's Avatar
What did you use to check the voltage on the ESM?
You are going about this in kind of a round-about way. You need a diagnostic tool to check the timing and the MAP voltage.
If all the things that you feel are causing your problems are truly the culprit then your car would have been as slow as a 4-cyl Accord before you installed the blower.
I still think it's timing and ESM related.
I ran with 92k miles on fouled plugs at the track and still put down a 13.6 @105 MPH.
Old 09-12-2007, 08:41 PM
  #160
mrsteve's Avatar
When I adjusted my ESM even 0.02v the car ran like a piece of dog shit. Still plenty of boost. But no timing at all.
Quick Reply: DEPRESSED!!! 221WHP with SUPERCHARGER!!!???!!!
