DEPRESSED!!! 221WHP with SUPERCHARGER!!!???!!!
#362
Haha, I didn't realize you had the same exact name as me, Samir. The ironic thing is I am about to put in my blower, hope I don't run in to the same problems.
#364
THE J35A2...
Originally Posted by Excelerate
If you want to find out if any of the coils are bad disconnect one coil at a time and see if the engine runs properly. If nothing changes the coil is bad. If it starts running oddly like it's running on one less cylinder then that coil is fine.
Originally Posted by SIRSIG
or you can unplug the connections while the engine is running. do it one at a time.
if you feel the engine surge as if it's gonna die that means the one you undo is OK, now, when you unplug the bad one the idle will stay the same, take that coil out and change it...
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
#366
2600lb CL
https://acurazine.com/forums/car-parts-sale-361/%24100-plus-perks-your-time-192029/
If you'd like to show up tonight, join us. But i won't be on race gas tonight, so no nitrous for me.
#368
SOLD
I think what he means is that, yes of course everyone wants to learn more about their car, but it is hard to learn about it WHILE fixing it. If you don't know how to fix it, it can be easy to fuck things up more than fix them. That, or at the very least waste a lot of time trying to fix things. For example, if you don't understand what static pressure is, it is best to find out BEFORE trying to fix it. Like others said, if you can't pinpoint the problem take it to a shop and learn for the future. I don't think anyone can be faulted for not knowing something, but they can be if they pretend to know something and get proved wrong.
#371
Or take some good advise & take all your mods off & start it over. Get it running right with out the mods 1st.
Dude this is the ONLY way your going to solve this. Add 1 thing back at a time & then run the car & make sure it's still running right.
It's a PITA & it's labor intensive & if your paying $ for it it's going to hurt your wallet.
At this point your only guessing here. Throwing $ at fixes that may or may not work. Wasting your time, & getting bummed you have a car that doesn't run right.
Everyone here has tried to help you.
If the base car isn't running right then moding it is a waste & your just going to kill the car & then be SOl.
#372
If you haven't already... Spend the $100.00 go to your Acura/Honda dealer and let them run a diagnostic on the car. I have been in a similar less painful situation as you, and it was well worth the expense.
#374
Blown is Best
Originally Posted by CleanCL
werd. this thread should be closed.
![Explode](https://acurazine.com/forums/images/smilies/explode.gif)
#375
Advance
Originally Posted by Allout
What are you talking about. We can't close this thread yet. I check in regularly on this thread - waiting for the motor to ![Explode](https://acurazine.com/forums/images/smilies/explode.gif)
#377
Advance
Swap that mug in than and handle business, why are you messing around with some motor that obviouslly has problems. Oh and when you go to do swap, just leave it at the shop and tell them to call you when they are making 330whp, to save you the headache.
#385
B A N N E D
So I finally get the time to run the car by my friend at the dealer, and they check it out. My injectors are staying open for twice as long as they should. Guess its time to replace the injectors and get over with this nonsense.
#387
4drs just wanna have fun!
#388
B A N N E D
Clean them for $24 each? I think they run about $35 new each, well my cost atleast. i dont remember. ill just pull off the ones from the other motor.
#391
#395
B A N N E D
I changed the injectors yesterday. one of the injector tips were broken, dont know why. now i have to replace all the plusga agin cuz they r fouled out. hopefully by the weekend
#396
B A N N E D
New problems. Injectors were replaced. The car ran good. Then a few days later the car would not idle and would stall. Pulled the plugs and found some completely fouled out some of tips were broken. Replaced the plugs agin with new plugs. ALso replacewd the IACV and still would not idle and would stall. The only way to get the car to run was to hold the gas pedal. But as of this morning, even that will not work.
I am stumped. I did have th car at the dealer yesterday and said everything as far as ECU is concerned seems fine. The injector issue I had prior was no longer there after replacing the injectors.
A clue I saw last nite was there was motor oil in the intake manifold and in the air intake plumbing> I have no clue ohw oil is getting into there. I checked the PCV valve it is not clogged but cleaned everything up anyways.
SO now car wont start, and if I try long enough, I might be able to get it to start, but wont idle. But if I can get it to start and I hold the throttle, driveability seems the same. It will pull and drive.
Any ideas?
Any ideas?
#400
B A N N E D
BRING YOUR CAR TO A PROFESSIONAL.
If the dealer checks it and says they dont know, what am I supposed to do? Why do you think I come here and ask. I ask for ideas and opinions. God damn fucking relax.
