Denso's resolve idle vibration?
here's the link to my original thread on this topic -- Acura claims it's my headers:
http://www.acura-cl.com/forums/showt...highlight=idle
Common on Type-S's due to the larger cams. Not ur headers either. Did u ever think it might be ur crak pulley???If not that then it could be a hundred things...but not ur headers and iridium plugs won't help!!
I have a bone stock 03 CLS w/ 3k on the clock and have experienced the vibration you mentioned since day 1. Like Ant7701 said, it is partly due to the relatively hot cams. I think the high compression ratio, transverse mount design and shitty motor mounts also contribute to this.
-Vlad
-Vlad
i put the densos in and didnt notice a damn thing. The only thing i can say i somewhat "noticed" was the quicker accelerator response. Not worth the money unless your are spraying or going FI and need colder plugs. You might notice it on the dyno with all the bolt ons, but the butt dyno feels nothing.
My car shakes and squeals when it is cold, once it warms up I can barely hear a thing. Dealer said they couldn't re-create the problem. Since I live an hour from the dealer I can't get it there cold and have it make the noise. I think one of the pully's is off balance, any idea what may have caused this?
the crank pulley actually made it better after I had that installed. I had the headers installed for a whole 7 months before I began to notice the vibration. Comptech said that occassionally, the flex joint on the headers can malfunction (this is that mesh pipe fitting) .. the purpose of this flex joint is to reduce vibration from the engine that is transmitted to the car and the rest of the exhaust system. That's why i'm curious to re install the stock headers to see if it'll go away.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
